Author Topic: Official Rythmik Subwoofer Thread  (Read 240061 times)
  • Trade Count: (+18)
Re: Official Rythmik Subwoofer Thread
« Reply #930 on: December 26, 2019, 18:36 »
Haha, went to jag place and got poisoned but my place cannot accommodate ported sub.
dual f18 will be great bro. Easier to integrate and have coherent bass note and signature.
It helps that this F18 is quite compact for a 18" sub! Impressed
Offline ngsk
« Reply #931 on: December 30, 2019, 10:07 »
Just gotten my rythmik f18 from peng. Just nice can start run in till christmas and start to do my calibration.
First impression, super heavy. The enclosure is just nice not too big as i thought. Run thru some bass demo clips just to try out, really nice the deep bass. Will try to align the f18 with my dual sub36 and see how it can perform.
Congrats bro! As ron said start BEQ,restore what's 'missing' b4 n enjoy!!!
As i said to another bro here,u might found the f18 gettig smaller in no time also! ;D ;D ;D
« Last Edit: December 30, 2019, 10:27 by ngsk »
Online Djblackfm
« Reply #932 on: December 31, 2019, 07:47 »
Caught this in FB.
Here is the G22, baby brother of the G25HP. Dual 12" opposed aluminum cone drivers in a sealed cabinet with HX800XLR3 amp.
Offline ngsk
« Reply #933 on: January 01, 2020, 08:22 »
This G22 is coming to SGP soon. Other than the already mentioned FV28/G28 a sealed F25hp might be in planning also with same driver/amp as the FV25hp,an upgrade version of F25. So many choices now from Rythmik: saeled,ported,dual opposed with 12",15",18" drivers.
Online rock123
    • Bass EQ for Filtered Movies
« Reply #934 on: January 01, 2020, 12:25 »
Looks good!
Not sure if peng have any estimated pricing for G22.
Offline kenshin07
« Reply #935 on: January 12, 2020, 12:23 »
After running in for couple of weeks, finally managed to align the 3 subs together. :)
This is only time align, not with audysee yet. :)
Placement of the subs,
Rythmik F18 -> Front Left
1st Starke Sub36 -> Sofa Left
2nd Starke Sub36 -> Sofa Right
AVR: Denon AVC 8500
Sub: starke dual sub36 / dual Rythmik F18
Player: Oppo 203
« Reply #936 on: January 12, 2020, 15:41 »
Great job bro, the left starke can have 0.2ms delay and rythmik 0.3ms delay for a perfect sum at MLP. Both first and second impulse aligned, they will sum in phase perfectly
Overall very good.
Next u can run audyssey now with all 3 subs as 1 , using single preout from avr
Then blend again mains + subs post audyssey , with XO engaged
Once ready, time for BEQ
Online rayleh
« Reply #937 on: January 12, 2020, 15:53 »
Overall very good.
Bro, can elaborate on how to align the subs and main post Audyessy. Able to share the steps?
« Reply #938 on: January 12, 2020, 19:19 »
First gotta identify the mains roll off. Measure mains alone with everything off. If it rolls off at 40hz, then your ideal XO or a good starting point will be one octave above that, ie 80hz. Once u have this ready, overlay then with your subwoofer measurements
Remember don’t use channel 4, use channel 3 to measure your subs, with channel 3 amplifier muted , then u know bass management working as intended
Overlay subs and mains
Use surround backs or surround as the acoustic timing reference speaker. Measure centre with subs muted, then measure sub with centre muted, overlay the impulse this time.
The second impulse from the speakers relate to the woofer. Align this woofer to your subwoofer, like the above done by ken . Use a sweep from 20-300hz, with subwoofers set to maximum LPF, 160hz or 200hz. The higher the better and more accurate
Alternatively, sweep from 60-300hz, overlay again, for the speaker impulse, look at the second rise
Once they are aligned, u will see that they will sum up at the XO point
« Reply #939 on: January 12, 2020, 19:26 »
When u have identified that a 5ms delay is required, this will need to adjusted for all subs. Meaning all subs will have 5ms delay. Because u have already aligned the delays between the subs previously. Now u are only adjusting for all subs against the speakers
Only adjust the delays on the subs, do not adjust the delays on the speakers.
Do look at the rest of the speakers as well, use a higher xo if necessary. If they are well integrated, u will not be able to localise the subs
Online rayleh
« Reply #940 on: January 12, 2020, 22:59 »
Thanks bro. I assume Audyessy needs to be turned off when taking the measurements?
« Reply #941 on: January 13, 2020, 08:29 »
No no, it should be turned on at this stage. The whole idea is to test and see if the mains and subs blend, so if it blends, when u watch your movies, they will sound good
That is why at this stage, crossover to mains from subs should be engaged, because each time you introduce a filter, they will introduce delays. This delay causes a phase shift
So u want to blend it in with these filters turned on and engaged. so u can see what they do and how to set it right, once set right, it will mirror your actual listening experience.
As for the initial  stage to switch off audyssey, it is to check what the individual subs response are at its location, the purpose is the excite their modes in your room, to find a spot where they blend and help each other. (Dual subs). That’s the main goal. At that stage, then yes, audyssey turned off. Once u find they help each other, u affix the subs to those positions. Only then u proceed with EQ
Offline ngsk
« Reply #942 on: February 09, 2020, 10:01 »
There's no review/measurement on the 12" Rythmik sub on data-bass.com but a guy posted a link on his review/measurement on the F12G @avsforum,this 1 with GR Research/Rythmik co-development 12" SW-12-04 paper cone driver, here's the link: https://www.erinsaudiocorner.com/loudspeakers/rythmik-f12g-direct-servo-subwoofer/
Although it's from 2013 but to what i know till date this sub is still the same as the reviewed 1.
« Last Edit: February 09, 2020, 10:07 by ngsk »
Online rock123
Offline ngsk
« Reply #944 on: March 21, 2020, 09:17 »
https://www.audiosciencereview.com/forum/index.php?threads/rythmik-l12-subwoofer-review.12140/
Review on the 'cheapest' Rythmik sub: L12 on audiosciencereview,first subwoofer Amir reviewed,not as details as data-bass.com but it's good to see smaller subwoofer get measured,the L12 is 599usd shipped in USA,the output/freq response is solid & distortion is also low @ the tested level.
