Author Topic: Official Rythmik Subwoofer Thread  (Read 210971 times)
Offline tane0019
  • 3rd Rock from the SUN - Middle Earth
Re: Official Rythmik Subwoofer Thread
« Reply #15 on: April 05, 2011, 19:10 »
thanks.
Offline tane0019
« Reply #16 on: April 12, 2011, 23:12 »
Just got the F12SE - A370PEQ2.
Slightly different control w.r.t. the link.
Is there a better manual somewhere ?
Offline anfieldude
« Reply #17 on: April 13, 2011, 06:22 »
Link to PEQ2 amp guide.
http://www.rythmikaudio.com/download/A370PEQ2.pdf
Link to sub tuner (Java) to help with some basic settings to blend with ur mains.
http://www.rythmikaudio.com/subtuner2.html
Let me know if u need further help and I will try to help.
« Last Edit: April 13, 2011, 08:18 by anfieldude »
Offline jaemon
« Reply #18 on: April 22, 2011, 11:44 »
which model should i go for if my room is 3m by 3m?
Offline NCMK
« Reply #19 on: April 22, 2011, 11:53 »
Go for the biggest you can afford.  F15 output is twice of F12 and the price difference is minimal.
Pioneer Kuro PDP-428XG  | Wyred SX-1000 Monoblock | Wyred ST500 Stereo Amp | Pioneer LX-86 AVR | HTPC | B&W HTM4 Diamond | B&W 805 Diamond | Mirage Omnisat OMD-5 | Ken Kreisel DX12012 | Rythmik F15SE  | Logitech Harmony One |
Offline jaemon
« Reply #20 on: April 22, 2011, 12:06 »
thanks, will take a look at f15.
Offline matix
« Reply #21 on: April 22, 2011, 12:23 »
Perfect square room?  There will be problems...   Seriously, I think F12 will be enough..  My 2 cents only...
Offline fengshenwee
« Reply #22 on: April 22, 2011, 12:26 »
3m by 3m is smaller than my room which 3.35m by 3.6m. F12 should be enough if u ask me. If u upgrading to a bigger to in the near future, just add another F12. :)
AR-T Legato II USB-SPDIF / Audio-GD Reference 8 DAC / W4S STI-500
Dynaudio Confidence C1 Black Piano Lacquer
Lifatec SILFLEX GLASS CABLES with OPTISILK JACKETING / Acoustic Revive USB-1.0SP / Black Cat Silverstar 75 BNC / Black Sand Cable Statement One + Silver Reference MKV / LessLoss DFPC Signature / Nordost Heimdall XLR / AudioArt Cable SC-5 SE
SOtM tX-USB / TAOC PTS-A Spike Plate / Oyaide MTB-6 Power Distributor / Telos Gold RCA Caps / Maestro Power Outlet / DA&T AC Filter x3
Offline jaemon
« Reply #23 on: April 22, 2011, 16:41 »
will there be any issue if i run f15 instead of f12? since that the price diff is not that big.
Offline soundaudio
  • I love HT
« Reply #24 on: April 22, 2011, 19:49 »
Brother,better act fast as from what I know the price will be increase sooner once the dealer is settled in Singapore
by  May or June.!!
Offline jaemon
« Reply #25 on: April 23, 2011, 00:09 »
Will buy once i get a buyer for my audio engin s8
Just wondering which to get only for now
Offline kristrip
« Reply #26 on: April 23, 2011, 00:25 »
if you've measured out the space for the f15 and have enough, and you're willing to pay the extra, then why not. But for your room, the F12 definitely has enough output to make you go deaf
Offline jaemon
« Reply #27 on: April 23, 2011, 01:24 »
thanks, in that case i will go for f12. can save then save since i wont be moving the system anytime in the foreseeable future
Offline anfieldude
« Reply #28 on: April 23, 2011, 10:26 »
jaemon,
If u do not listen to ur stuff loud, the F12 is sufficient, if u need more headroom, get the F15.
Offline jaemon
« Reply #29 on: April 26, 2011, 10:48 »
If im using the sub for mostly movie should i opt for f15? As i rdered the f12 just afraid that it might not be powerful enough
