Author Topic: Does ikea carpet helps to reduce sound rebounce in a small room ?  (Read 4430 times)
Offline melmeow
seeking advice. Currently when i am playing music...i can feel the sound "rebounce" from the ceramic floor upwards to my foot (sitting on a higher chair so my legs are above ground) ... i seems shops laying carpet on the floor....will that help ? Tks !
Offline Wenda
Re: Does ikea carpet helps to reduce sound rebounce in a small room ?
« Reply #1 on: February 07, 2011, 22:08 »
Yes it will.
Offline big bad wolf
« Reply #2 on: February 08, 2011, 10:20 »
You must buy those carpets that are highly recommended by Steero File , Wat Hi Fly.
They can tell you which one will give sweeter highs , wider sound stage ,etc etc.
 ;D  :D  :P
Offline garbage
    • my blog
« Reply #3 on: February 08, 2011, 10:30 »
i think the question should be "does carpeting help sonics?". i didn't hear much diff when i put in a carpet... but i really just wanted to beautify the room.
Offline melmeow
« Reply #4 on: February 08, 2011, 19:46 »
gosh even carpet also got audiophile grade .....
Offline mHiFi
« Reply #5 on: February 08, 2011, 20:20 »
Yes carpet helps. Hard surface is not good for sound as it reflect and mesh it up. I read some post in this forum using silk carpet is the best which cost few $K!
Why not just throw few blankets on the floor first to see if it helps before heading to ikea?
Offline wsdavidcheah
« Reply #6 on: February 08, 2011, 20:25 »
Why Ikea????
Offline Wenda
« Reply #7 on: February 08, 2011, 20:46 »
It is priced reasonably and quite a lot of choices. Try to speak to the carpet, check whether it has some kind of absorption or not (a bit crazy but I got my carpet from IKEA also, choosing the cheapest and has the most absorption). I think it costs me about 120 for 2m carpet.
« Reply #8 on: February 08, 2011, 20:51 »
Works best if you also use ikea drapes and furniture  :o :o :o ;) especially effective for ABBA singles
Offline Austrich
« Reply #9 on: February 08, 2011, 20:58 »
..get the wrong stuff it will become battle of waterloo ...  ;D
Offline ryder
« Reply #10 on: February 08, 2011, 22:06 »
Get a thick carpet, the thicker the more effective. Ceramic tile floor is not too good especially if the area is large. I don't know what is the correct term for the type of carpet posted by Garbage. That pile may be made by artificial fibre and not wool, hence it doesn't provide too much absorption. The idea of a carpet is to absorb the reflections of high frequencies as much as possible, hence the thicker the better.
Offline ryder
« Reply #11 on: February 08, 2011, 22:13 »
As an add-on, you mention your room is small. Usually the sound reflection is not only due to the floor but the surrounding walls. You need to treat the walls as well.
Offline Wenda
« Reply #12 on: February 08, 2011, 22:14 »
garbage's appears to be very sparse. Just a cheap trick: Speak to the carpet to test :)
Offline domho8
« Reply #13 on: February 08, 2011, 22:19 »
Get francis to organise "Carpet" shootout.  ;D
Offline melmeow
« Reply #14 on: February 08, 2011, 22:22 »
francis place got audiophile R&D lab issit ?? simi also can go his place to do proof of concept ?
