Author Topic: Need yr help set up my home theater in new house.  (Read 708 times)
Offline zacko69
« on: December 26, 2010, 00:12 »
Hi to all bro,i have a problem with my  home theater 7.1 system.
My 7 speaker is Jamo THX certified on it,subwoofer is whafadale
& Pioneer VSX-A4ASi 7.1 system.The problem is right hand side
speaker is working which the rest speaker is not working.
My question is ,is it 180w amp can support my Jamo 200w speaker?
Pls help me.............. thanks.
Offline kemp98
  • What do all men with power want? More power.
Re: Need yr help set up my home theater in new house.
« Reply #1 on: December 26, 2010, 01:09 »
First check if you have connected your speakers' wire correctly to the Pioneer. Secondly, ensure you have select 7.1 speaker setup in the setup menu. All else fail, reset your pioneer to factory setting. If still persist, contact service center.
« Last Edit: December 26, 2010, 08:06 by kemp98 »
Denon AVR-3808A | Emotiva UPA-500 | Paradigm Monitor 9 v.6 | Paradigm CC-290 v.5 on Auralex Mopads | Mirage Omnisat v.2 on Atacama Nexus 10 stands | SVS 20-39 PC-Plus on Auralex Gramma | Anti-mode 8033 | Samsung 55D7000LN | Starhub HD STB | Sony BDP-S790 | Himedia HD900B | Belden 1313A/1307A, Belden Studio 814/497mk2, Belden 1505F (interconnects), Canare LV-77S (sub), Monoprice optical, Aiborg HDMI | Tacima CS929 power distributor | Sony RM-VL600 remote
« Reply #2 on: December 26, 2010, 08:35 »
Define 'not working'? Its too brief...even if you somehow messed up with the connection at the speaker binding posts, you should still be able to hear hissing sound. Is there any error message appearing on your AVR? e.g. wrong polarity etc?
Unless your definition of 'not working' is no sound coming out from all speakers except your right one? You got use test tone to test right?
