As mentioned in the link posted by BTW, below is the diagram. Try to use 2.2uF only and add the above L-Pad resistors. Try R1 = 3 ohm and R2 = 10 ohm for a start, assuming the ST is about 5dB more sensitive than your speaker. Both resistors must be 5W or higher. R1 is in between the capacitor and tweeter.
my ST sounds better after added the resistors.. not so sharp and loud anymore.. but I still duno if it's the best it can do
