Features:- SATA interface: SATAII 3.0Gb/s- NCQ up to 32 commands- High and Reliable ECC capability up to 16bits/sector- S.M.A.R.T features optimized for ssd- Enhanced power managent- Power supply: Vcc=5.0V +/-5%- Operating temperature: Commercial: 0C to +70CPerformance:- Sequential Read Rate: 285MB/sec- Sequential Write Rate: 275MB/sec- Sequential Read IOPS: 20,000 IOPS(4kb random read)- Access Time: 0.1msSpecifications- Compatibility: Full SATA hard disk compatible- OS Support: All- Package: Complete metal housingReliability:- MTBF: >1,000,000 hours- Sudden power-off recovery- Bit error monitoring and managent- Dynamic and static wear-leveling- Dynamic bad block management- SMART commands and additional SSD monitoring
Features:- Form Factor: 2.5 inch- Interface: Serial ATA SATA 3.0Gb/s- Capacity: 64GB- Nanflash type:MLC- NCQ up to 32 commands- High and Reliable ECC capability up to 16bits/sector- S.M.A.R.T features optimized for ssd- Enhanced power managent Performance:- Sequential Read Rate: 245MB/sec - Sequential Write Rate: 245MB/sec - Sequential Read IOPS: 20,000 IOPS(4kb random read)- Access Time: 0.1msSpecifications- Compatibility: Full SATA hard disk compatible- OS Support: All- Housing: Complete metal housing with black or silver color- Dimension: 100x70x9.5mmReliability:- MTBF: >1,000,000 hours- Sudden power-off recovery- Bit error monitoring and managent- Dynamic and static wear-leveling- Dynamic bad block management- SMART commands and additional SSD monitoring Power Consumption:- Power supply: Vcc=5.0V +/-5%- Standby: 0.5W- Operation: 2W Environment:- Operating temperature: 0C to +70C - Storage temperature: -40C to +85C- Vibration endurance: 20G- shock endurance: 1500G
Features:- SATA interface: SATA 3Gb/s-Buffer:64MB SDRAM-NCQ up to 32 commands-High and Reliable ECC capability up to 16bits/sector-S.M.A.R.T features optimized for ssd-Enhanced power managent- Power supply: Vcc=5.0V +/-5%- Operating temperature: Commercial: 0C to +70CPerformance:-Sequential Read: 230MB/sec-Sequential Write: 160MB/sec-Sequential Read IOPS: 10,000 IOPS(4kb random read)-Access Time: 0.1msSpecifications- Compatibility: Full SATA hard disk compatible- OS Support: All- Package: Complete metal housingReliability:- MTBF: >1,000,000 hours-Sudden power-off recovery-Bit error monitoring and managent-Dynamic and static wear-leveling-Dynamic bad block management-SMART commands and additional SSD monitoring
Features:- SATA interface: SATA 3Gb/s-Buffer:64MB SDRAM-NCQ up to 32 commands-High and Reliable ECC capability up to 16bits/sector-S.M.A.R.T features optimized for ssd-Enhanced power managent- Power supply: Vcc=5.0V +/-5%- Operating temperature: Commercial: 0C to +70CPerformance:-Sequential Read: 210MB/sec-Sequential Write: 110MB/sec-Sequential Read IOPS: 10,000 IOPS(4kb random read)-Access Time: 0.1msSpecifications- Compatibility: Full SATA hard disk compatible- OS Support: All- Package: Complete metal housingReliability:- MTBF: >1,000,000 hours-Sudden power-off recovery-Bit error monitoring and managent-Dynamic and static wear-leveling-Dynamic bad block management-SMART commands and additional SSD monitoring
any warranty?
256 have but the price is around almost close to 700-800 liao.
Expensive still though, will check to let you know.
