Author Topic: are there nottingham analogue owners here?  (Read 14881 times)
Offline DIYer Straits
  • 6N6P Über Tube
Re: are there nottingham analogue owners here?
« Reply #15 on: June 19, 2010, 12:33 »
Read that Tom Fletcher designs Nottingham tt to be used with unipivots. You can call them to ask more. Strangely they don't seem to have an email contact. Pm me if you want the Uk number.
Interesting. Ironically, the Space arm is not a true unipivot. It was at one stage but NA replaced the pivot with a tiny bearing instead. Yes, I actually took one apart to see how it worked. ;D Just as the Wilson Benesch Act 2 is not a true unipivot. They had also briefly dabbled with a parallel tracker called the Paragon.
Laptop via XMOS
Khadas Tone DAC
Custom 6N5P/6N6p Aikido Preamplifier
Modded TPA3118 Class D amplifier/Modded TPA 3255 power amplifier/Anaview AMS1000 power amplifier/KT88 SE
FAST with a 6.5" Satori mid and a 12" Pro woofer/Some Satori in birch ply cabinets with a PR/KEF R300
To be updated
  • 6N6P Über Tube
« Reply #16 on: June 19, 2010, 12:46 »
i am puzzled. ???
just 3 weeks ago, i ran into our friendly neighbourhood SIA steward.
he told me how he got rid of his SME and nottingham (the very same unit the thread starter is using), and is now using a refurbished Lenco.
after clean up and realignment, the whole Lenco TT cost only around $1K
he said this Lenco setup is the best that he has ever heard, and that he is so relived to have wakened up, and be able to get rid of his previous TTs.
either this man is deluded or we are missing something here?
has anyone heard his Lenco setup yet? if this TT is as good as he claims, i wanna have one too!!! seriously.
If this is true then I'm rich!!!!! I've got more than one Lenco L75!  ;D
To be honest, the Lenco is no big a deal. What's got going for it is a stonkingly humungous AC motor that is bigger than the Garrard's. Probably the largest ever used in a commercially available turntable. Coupled via an idler wheel to a medium mass platter, you will get pretty good constant speed with low wow and flutter. In fact, the motor weighs more than the platter and body combined! Monster torque unlike the puny kit used in the NA.
Unfortunately, you will need a lot of work to get it to sing. The original plinth resonates so a very high mass plinth is required to damp all the chassis. The original arm is crappy, very lacking in dynamics due to its pretty awful bearings that deteriorate over time. What would expect if it's made of rubber? After removing the arm, the original hole is too far forward for a regular 222mm tonearm so a new hole has to be made. As a result a new arm board is needed. Then the entire chassis has to be grounded or else the steel chassis will produce a lovely magnetic field that'll cause your speakers to give you  nice 50Hz eardrum massage. Did I mention that the idler wheel is made of rubber which may harden over time?
Having said all that, it is "better" than most belt drive of its era even after refurbishment and upgrading. Overall cost? Definitely more than $1k. Is it worth it? One man's meat ....  ;D
Laptop via XMOS
Khadas Tone DAC
To be updated
Offline j45yip
« Reply #17 on: June 19, 2010, 13:18 »
...you're right. he's deluded so don't pay too much attention to what he said. the 75 is nothing special  :)
i am puzzled. ???
Vecteur D2 CD Transport, AN1865n-k Non-OS DAC
Thorens TD124MkII, MicroSeiki MA88, Expert Stylus 103 / Midas Touch
DACT CT100 / Custom Shunt Regulated PSU
5687 WOT Preamplifier
Behringer DCX2496
Type 45 SET monobloc / Radian950pb / AH204 Azurahorns
UcD180AN / Double Usher 15HM in Custom Vented Enclosures
Offline ...
« Reply #18 on: June 19, 2010, 13:27 »
i am puzzled. ???
ashly actually had the unit rebuilt,i think. my next toy could be 1 of these ;D
  what i'm sceptical about is his remark that the original arm is one of the best tonearms around, and it is the best for the l75
« Last Edit: June 19, 2010, 13:39 by ... »
The best
Offline ...
The best
Offline malsound
« Reply #20 on: June 19, 2010, 13:37 »
http://www.pinkfishmedia.net/forum/showthread.php?t=56705
http://www.vinylengine.com/phpBB2/viewtopic.php?t=16579
-Tom, Real or Rumor  ???
https://youtu.be/y3RIHnK0_NE
https://youtu.be/FELbmXdS4xM
Offline jeromelang
« Reply #21 on: June 19, 2010, 13:38 »
i questioned him at length, since i found his comments so interesting, so contrary to common knowledge.
he did mentioned about the tremendous amount of work that went into restoring the Lenco, through the help of some mysterious malay guy.
he mentioned that after trying various arms, the original arm (replaced with original and "new" bearings) still sound best.
and he also mentioned that the original resonant plinth material sounds best, against other more dampening materials touted by people on the internet.
the gist of it is - every part of this TT were designed to complement one another, so they sound together, sinergistically, greater than the sum of all the parts.
but he emphasized - that it could only have come - with the technical help of someone who knows this venerable TT design inside out, and who process all the necessary spare parts to replace the worn-out ones.
i have never seen a man spoken with more convictions. a conviction that can only have come having heard the lenco refurbished step-by-step over many agonising months, and each new stage of upgrade compared at length to the 2 other previous TTs he gotten rid off.
i think it is worthwhile to check the lenco out. don't you?
« Last Edit: June 19, 2010, 13:40 by jeromelang »
Main System: Sources Sony SCD-1, SCD-XA9000ES (Black), Michell Gyro SE, SME V, Lyra Skala. Amplifiers Pass Lab Aleph Ono, Sony TA-E1, Pass X350. Speakers Sony SS-M9ED. Cables Straightwire Crescendo interconnects, double run speaker cables. All Hirakawa powercords plugged directly to wall mains, dedicated line for audio only.
Second System: SCD-XA9000ES (Gold), Pro-Ject Genie 1.3, Pass X2.5, Sony TA-N1. Sony SS-M7, Straightwire Virtuoso Interconnect. Straightwire Serenade speaker cables.
Offline ...
« Reply #22 on: June 19, 2010, 13:49 »
eh, don't say 'gotten rid of' ok, you make it sound like i got a bad deal >:( ::) ??? ;D the insensitivity.. ;D i'm actually very happy with the table. anyway i spoke to him at length about the l75 and it seems he likes it more for the prat and drive than other common attributes. it probably was the prat and drive of the l75  that was the game ender for him
« Last Edit: June 19, 2010, 13:58 by ... »
The best
Offline ...
« Reply #24 on: June 19, 2010, 14:05 »
I'm a current owner of the Spacedeck with a Schroeder No 2FW tonearm. I really like it a lot for its neutrality and its ability to float images from a very dark background. The addition of a Mystic Mat and a Clearaudio Synchro enhances the playback further.
Heard the Hyperspace at my friends place. Wonderful set!
i'm really piqued about the mystic mat. ::) how does the clearaudio compare to the wave mechanic?
      i'm thinking neutrality too when describing the hyperspace but strangely enough, the hyperspace in my setup isn't "dark" sonically,as most describe it over the net,some recordings do sound quite sunny :)
« Last Edit: June 19, 2010, 14:08 by ... »
The best
Offline jeromelang
« Reply #25 on: June 19, 2010, 14:16 »
wha. so touchy ah  :-[
i dunno. it must take very compelling reasons to give up (hope this is more sensitive wording) the 2 more expensive TTs, and suffer big $$$ losses.
that's why i'll be so interested to hear his Lenco setup, and your nottingham setup.
lacking prat and drive aside, what do you think are the saving grace of the nottingham TT he sold you?
« Last Edit: June 19, 2010, 14:19 by jeromelang »
Offline ical
  • Vinyl Kills The MP3 Industry
« Reply #26 on: June 19, 2010, 14:46 »
Bro ical, long time no see. How are you my friend? Welcome to the world of the black pizza. Your collection of LPs is very impressive, and in such a short time too.
You are spot-on with you guess that it is a SME. You know my taste. But mine is not a standard SME 30/2 in that I changed the venerable SME V with PAD AK phono cable for a Basis Vector 4 with very good results. Much more even sounding with details and clarity. But I had to give up the superb deep bass of the V in return.
The SME 30, because of its design sounds like a LP12 on steroids. It marries the liveliness and speed of the best suspended TT, with the scale, solid imaging, neutrality and wide dynamic range of the high-mass  designs.  It matches my taste exactly in a fuss-free design (besides the industrial looks).
Bro, it been a long time since we last met. I've been very busy with work. Damn!! The dark side is too strong to resist.  :(
Guess we've quite similar taste. SME with Basis Vector 4??!! That's cool! Love this arm! Good choice! I believe you're the only one locally that use this combo. Now I'm looking those black beauties like SME, Basis (just love their arm and it's transparency) and Transrotor.
Bro, you help to solve the myth.  :D Hype has been surrounding it recently which also puzzled me as well.  ??? Heard it a few times but doesn't really impress me. But at that price, it a very good TT.
« Last Edit: June 19, 2010, 15:16 by ical »
P9/ RB1000 | DV-XX2 MkII | PS.30RDT | TecnoWeight | STB-MS/ STB-CM | Clearaudio Matrix | Furutech DF2 | SK-EX | RL30Mk3/ RGC24/ REM8/ RCI3/ RR77 | Isotek Sigmas | CSE RK100 | QC24/ II-40 & nos Tungsol 6550 | SHL5 & Sound Anchor | Solidsteel 5.4 | SCB-RS50G/ TITE35S/ 25MF | Stax 717/ O2Mk1/ 404LE
Offline ...
« Reply #27 on: June 19, 2010, 16:58 »
kidding la ;D the hyperspace doesn't lack prat nor drive,it is just that these are contained in the right context,eg the drummer within the soundstage. this is one of the reasons why i commented that good recordings sound live.music isn't all drive and prat,although i agree that having lots of it is pleasant to the ears,but it would be inaccurate.my roksan is like that,lots of prat and exciting to listen to and yes,its distorted,but extremely thrilling and i have to admit on rock i prefer the roksan... 8)
The best
Offline ...
« Reply #28 on: June 19, 2010, 17:04 »
eh, don't get fancy ideas can? ;D i most probably will buy your l75(remember our conversation down at koba?)
The best
Offline ...
« Reply #29 on: June 19, 2010, 17:12 »
leafing through the site kinda gives me the impression that fletcher was elbowed out of nottingham analogue,but his designs look promising as per the comments
The best
