Author Topic: moerch dp6 optimisation assistance  (Read 3641 times)
Offline ...
Re: moerch dp6 optimisation assistance
« Reply #15 on: May 03, 2010, 07:54 »
It seem your have done some homework with matching your hyperspace deck with DP-6 and with the incisive nature of the 17D3 this should make a interesting combo but I would advice against going dry with a cart such as 17D3 as it may sound too honest for most folks, just inject 0.1ml at a time and listen for a couple of days before decided to add again.
Remember to try to place the weighs as close to the arm bearing as possible as it sound better that way.
With their range of normal armwand it can be a challenge for most people to do a perfect overhang as the cartridge is resting against a narrow tube with the arm lifter in a crucifix arrangement( look from the top) but with the square profile  that your cartridge has, you should have a easier time with the alignment.
Just focus your eye more on the straight of your cartridge as the shiny J-wand can play tricks with your eyes and get a bright LED light I am sure that will come in handy and happy spinning. 8)
Thanks a bunch, this is the kind of pointers i was searching for
The best
