Author Topic: please recommend a relevant 5751  (Read 7967 times)
Offline DIYer Straits
  • 6N6P Über Tube
Re: please recommend a relevant 5751
« Reply #30 on: April 09, 2010, 10:11 »
in some things like soundstage yes, though the dared presents instruments with a more accurate timbre and sounds more lifelike
Interesting, something that have to investigated further. I guess technology in metallurgy has finally caught up with the Sino-tubes which allows them to be improved and not just copied. ;D
On the other hand, if these tubes brought "life" to your previously dull amplifier, I wouldn't want it to put them in my already lively system.
Laptop via XMOS
Khadas Tone DAC
Custom 6N5P/6N6p Aikido Preamplifier
Modded TPA3118 Class D amplifier/Modded TPA 3255 power amplifier/Anaview AMS1000 power amplifier/KT88 SE
FAST with a 6.5" Satori mid and a 12" Pro woofer/Some Satori in birch ply cabinets with a PR/KEF R300
To be updated
Offline ...
« Reply #31 on: April 09, 2010, 17:48 »
it is sounding better and less chinese, only fault i find is the sound isn't very interesting,smooth but that it,waiting for it to ripen more
The best
Offline ...
« Reply #32 on: April 10, 2010, 13:32 »
sound has mellowed out, and is too euphonic to boot, but very flat response curve, but now my unison is listenable,will use these tubes until I get some amperex bugle boys. the fm are good value, not spectacular,not yet as it is still running in
The best
Offline ...
« Reply #33 on: April 12, 2010, 12:09 »
giving up on the fm, very good performance, just not quite interesting :(
The best
  • 6N6P Über Tube
« Reply #34 on: April 12, 2010, 13:14 »
It's the amp that needs changing as it's probably designed to be as laidback as possible. Sad.
Laptop via XMOS
Khadas Tone DAC
To be updated
Offline ...
« Reply #35 on: April 12, 2010, 13:47 »
you're probably correct, or maybe the dared is that fantastic; whichever way it would be, i may just rotate use of these two
The best
Offline ...
« Reply #36 on: April 20, 2010, 09:35 »
tubes are finally showing their fruits, my rig is sounding satisfactory,it s been a long few weeks, and it will be better when it fully runs in ;D
The best
