• Forum
  • Main
  • About
  • Donation
 V
Search:
  • Home
  • Help
  • Login
  • Register
Welcome, Guest. Please login or register.
Did you miss your activation email?
September 04, 2010, 04:51
Login with username, password and session length
XtremePlace Forum > Sales Galaxy > Planet Mass Order > Topic: 3rd MO: OPPO BDP-83 + Hardware Modification (CLOSED)
« previous next »
Pages: [1] 2  All Go Down Print
Author Topic: 3rd MO: OPPO BDP-83 + Hardware Modification (CLOSED)  (Read 6902 times)
Darthfunk
Full Member
Offline Offline
Da funk banana
« on: July 21, 2009, 00:01 »
The Official OPPO BDP-83 MO has started
MO will officially closed on 16 Aug Sunday
Special MO price for OPPO BDP-83 @ $999 w/gst includes:
- Hardware modification (Region Free DVD & Blu Ray)
- AIX Audio Calibration & Sampler Blu-ray disc
- Free Spears & Munsil disc
- Accessories
- Free delivery
Retail price is $1069 direct from SLT Tech
Shipment is expected to mid to end Aug. ETA will be confirm again.
Units allocated to you will be base on a first come first serve basis with full details confirm and date paid.
To place an order please scroll down for full order details and terms & conditions.
OPPO BDP-83 Blu Ray Disc Player
Complete Media Support:
    * Blu-ray Disc - The high definition Blu-ray Disc™ format provides pristine video and audio quality for your home entertainment.
    * BonusVIEW - BD "Profile 1.1" enables "picture-in-picture" and secondary audio features for viewing director or actor commentary while the main movie is playing.
    * BD-Live™ - The BDP-83 support BD "Profile 2.0" and contains all necessary hardware - audio/video decoder, Ethernet port, and 1GB of internal storage - for BD-Live.
    * DVD Up-Conversion - The BDP-83 uses the same VRS™ by Anchor Bay (DVDO) de-interlacing and scaling technology as in our award-winning DV-983H DVD player. The up-converted picture quality bridges the visual gap from your current DVD library to Blu-ray discs.
    * DVD-Audio - The BDP-83 plays DVD-Audio and supports both stereo and multi-channel high resolution audio programs. Users can select whether to play the DVD-Audio or the DVD-Video portion of the disc.
    * SACD - The BDP-83 plays Super Audio CD (SACD) and supports both stereo and multi-channel high resolution audio programs. Users can select whether to output the DSD (Direct Stream Digital) signal in its native format or convert it into PCM.
    * Additional Media Formats - Additional disc and file formats, such as audio CD, Kodak Picture CD, AVCHD, MKV, and other audio/video/picture files on recorded discs or USB drives can be played back on the BDP-83.
Unparalleled Video Quality:
    * VRS™ by Anchor Bay - The BDP-83 incorporates Anchor Bay's award-winning Video Reference Series (VRS) technology, and delivers a picture that is cleaner, smoother, true-to-life and free of artifacts.
    * Full HD 1080p Output - The BDP-83 features user selectable video output resolutions, including 480i, 480p, 720p, 1080i, and up to 1080p 50 or 60Hz.
    * True 24p™ Video - Many Blu-ray Discs are recorded at 24 frames per second, the same frame rate as the original movie's theatrical release. The BDP-83 can faithfully redeliver the original frames using 1080p 24Hz output (compatible display required) for smoother motion and a flicker-free, film-like home theater experience. It can also restore the original 24 frames per second progressive-scan video from well-authored DVDs and output as 1080p 24Hz.
    * Source Direct Mode - For users who wish to use an external video processor, high-end audio/video receiver or display, the BDP-83 offers a "Source Direct" mode. The original audio/video content on the discs is sent out with no additional processing or alteration.
    * Multiple Zoom Modes - The BDP-83 supports multiple levels of aspect ratio control and image zooming, including a vertical stretch mode for customers with a 2.35:1 CIH (Constant Image Height) display system.
    * HDMI - HDMI is an all digital interface for the cleanest possible connection. It delivers high-quality digital video and audio through a single cable. The BDP-83 features an HDMI v1.3 output with 30-bit and 36-bit Deep Color support.
High Fidelity Audio:
    * Dolby® TrueHD - Dolby TrueHD delivers lossless studio master quality audio designed specifically for high definition entertainment. The BDP-83 supports bit-stream output of Dolby TrueHD via its HDMI 1.3 output. It can also internally decode Dolby TrueHD into LPCM and output via HDMI or the 7.1ch analog audio output terminals. Other varieties of Dolby Digital audio formats are also supported.
    * DTS®-HD - DTS-HD delivers up to 7.1 channels of surround sound and audio that is indistinguishable from (DTS-HD High Resolution) or identical to (DTS-HD Master Audio) the original studio master. The BDP-83 supports bit-stream output and internal decoding of DTS-HD High Resolution and DTS-HD Master Audio. Other varieties of DTS audio formats are also supported.
    * 7.1-Channel Analog Output - Individual analog 7.1-channel surround outputs are ideal to connect to a 7.1-channel or 5.1-channel surround sound system. The BDP-83 delivers an incredible sound stage and an immersive surround experience.
    * Dedicated Stereo Output - The BDP-83 features a dedicated 2-channel analog output with specially optimized Digital-to-Analog Converters and output driving stage.
    * Digital Optical and Coaxial Outputs - For simple and easy connection to more traditional A/V receivers, the BDP-83 features both optical and coaxial outputs for digital audio.
Ultimate Convenience:
    * Dual USB Ports - Two USB 2.0 high speed ports are provided, one on the front panel and one on the back. Users can enjoy high definition video, high resolution photos and music directly from their USB drives.
    * PAL/NTSC Conversion - The BDP-83 supports NTSC and PAL systems for both disc playback and video output. It can also convert content of one system for output in another. (Subject to DVD and BD region restrictions.)
    * Back-lit Remote Control - The BDP-83 comes with a fully back-lit remote control for ease of use in dark home theaters. With its ergonomic button layout and clear labeling, operating the Blu-ray Disc player is easier than ever.
    * Universal Power Supply - The BDP-83 features a wide-range world power supply that is compatible with the AC power of all regions. No worries about damaging the player due to incorrect power voltage.
    * External IR - For integration into home theater control systems, the BDP-83 provides external IR remote IN and OUT ports.
    * RS232 Control (optional) - For custom installation, the RS232 control option can be special-ordered at an additional cost.
    * HDMI CEC - HDMI Consumer Electronics Control simplifies the home theater by allowing a single remote control to operate multiple devices.
General Specifications:
    * Power Supply: Power Supply: ~ 100V – 240V, 50/60Hz AC
    * Power Consumption: 35W (0.5W Standby)
    * Dimensions: 430mm x 336mm x 77mm, 16⅞ x 13¼ x 3 inches
    * Mass: 5.1kg / 11.2 lbs
    * Region Enforcement: DVD Region 1 (non-adjustable) and Blu-ray Region A (non-adjustable)
Back View
Main Board
Official OPPO Website:
http://www.oppodigital.com/blu-ray-bdp-83/blu-ray-BDP-83-Features.aspx
Order Details and Terms & Conditions
1) The MO price for OPPO BDP-83 is $999 includes Hardware modification (Region Free DVD & Blu Ray), Free Spears and Munsil disc and Free delivery
2) The MO price for OPPO BDP-83 is $899 with free delivery.
3) Spears & Munsil disc can be purchase at $20 with any unit ordered.
4) Provide your full name, address, mobile number, and email address to confirm your interest.
5) To confirm your order,  I will be collecting full payment through bank transfer.
6) Free delivery is provided, SLT Technologies Pte Ltd will make delivery arrangements with you.
7) Each set comes with 1 year manufacturer’s warranty. (Please note that SLT Technologies is the official reseller for OPPO. Check here for official OPPO resellers http://www.oppodigital.com/wheretobuy.html. SLT Technologies will not be responsible for units bought from parallel importors and will not cover any warranty bought from 3rd parties.)
8.) If you have further queries on OPPO products, you can email SLT Tech at sales@slttech.com.sg.
9) Please make payment to:
Name: Lim Yu Jin
Account DBS Savings Plus 029-6-018466
a) Online transfer is strongly preferred if you have a DBS or POSB account.
However if you have a UOB or Citibank account you can pm me to get my account number to transfer directly.
b) For online transfer from other banks, the branch code is TAMPINES CENTRE BRANCH (DBS).
Please note that it will take 3 workings days for your funds to be transferred over to my account.
c) For ATM Transfer, please keep your receipt as proof of payment. In case of any discrepancy or dispute, your receipt is your proof of payment. You are required to scan and email your receipt to me at darthfunk@gmail.com
d) Once payment has been made, please drop me a pm or email me (Do not sms me).
Once payment has been made please pm or email me with the template. (This is to cut down my administrative time as I would need to send your order details and payment to SLT Tech).
Dear Yu Jin,
I have made payment on (date & time) for amount of (amount), for my order:
Name & Nick:
Address:
Contact Number(s):
Email Address:
Item Ordered: (Make & Model Number, Quantity ordered)
Payment Reference Number (if any):
Regards,
Your Name
For further details please contact me @ 97639663 Yu Jin or email me @ darthfunk@gmail.com
« Last Edit: September 24, 2009, 22:54 by Darthfunk » Logged
Darthfunk Mini Review
OPPO DV-983H
OPPO DV-980H
Yeek
Full Member
Offline Offline
Re: MO: OPPO BDP-83 (Interest Check)
« Reply #1 on: July 24, 2009, 10:27 »
1 more to blast off Smiley
Logged
Yeek
Full Member
Offline Offline
« Reply #2 on: July 25, 2009, 11:03 »
So close yet so far....last 1 to kick start MO Smiley
Logged
Darthfunk
Full Member
Offline Offline
Da funk banana
« Reply #3 on: July 26, 2009, 13:11 »
For those interested drop me a pm with your full details.
For those whom have confirm their details please proceed with the payment.
MO price at $999 including hardware mod + free S&M disc
Interest Check List
1. Yeek - Paid 260709
2. Code - Paid 290709
3. moosekow - Paid 260709
4. slave8 - Paid 290709
5. Terirapt - Paid 280709
6. Kenneth - Paid 310709
7. yuke - Paid 030809
8. StevenCCF - Paid 030809
9. snnaks - Paid 040809
10. Desmond Low - Paid 050809
11. JRIX - Paid 050809
12. Dutchman - Paid 060809
13. ckt - Paid 070809
14. Wong T W - Paid 070809
15. Videophile - Paid 070809
16. Bono - Paid 080809
17. wentworth - Paid 080809
18. Pure - Paid 090809
19. wav3 - Paid 100809
20. wav3 - 2 units Paid
21. lobster - Paid 100809
22. Sillycar - Paid 110809
23. Joseph - Paid 110809
24. Shaunt - Paid 130809
25. Odybro - Paid 140809
Shipment is expected to arrive mid to end Aug will confirm again when I check with the distributor.
« Last Edit: August 14, 2009, 22:31 by Darthfunk » Logged
OPPO DV-983H
OPPO DV-980H
Asiatic
Newbie
Offline Offline
Re: 3rd MO: OPPO BDP-83 + Hardware Modification
« Reply #4 on: July 27, 2009, 15:01 »
Bro Darthfunk,
Won't be in this MO, will contact you when i want it.
Thanks for the notification.
Logged
Samsung L7 40"
Denon AVR-3808A
Oppo DV-983H
Marantz CD-6001
Front Speakers - Axiom Audio M80
Centre Speakers - Axiom Audio VP150
Side Surrounds - Axiom Audio QS8 (Quad Pole)
Rear Surrounds - Axoim Audio QS4 (Quad Pole)
Power Distribution Block - Supra
Speaker cables - Supra PLY 3.4
Surround Speaker Cables - QED Classic
Interconnects - Supra
Yeek
Full Member
Offline Offline
« Reply #5 on: July 28, 2009, 10:22 »
Hmmm...bro Darthfunk, will MO still proceed if we have less than 10 orders?
Yeek
Logged
Darthfunk
Full Member
Offline Offline
Da funk banana
« Reply #6 on: July 28, 2009, 12:31 »
Quote from: Yeek on July 28, 2009, 10:22
Yeek
Yup distributor says ok so no worries.  Smiley
Logged
OPPO DV-983H
OPPO DV-980H
Yeek
Full Member
Offline Offline
« Reply #7 on: July 29, 2009, 00:15 »
Cool!
Thanks bro!
Logged
kn
Guest
« Reply #8 on: August 03, 2009, 14:32 »
Hi, the $999 moded includes the S&M disc, does it incl the HDMI cable?
Logged
Darthfunk
Full Member
Offline Offline
Da funk banana
« Reply #9 on: August 03, 2009, 21:37 »
Quote from: kn on August 03, 2009, 14:32
Yes its included in the accessories box
Logged
OPPO DV-983H
OPPO DV-980H
tdk2999
Newbie
Offline Offline
« Reply #10 on: August 06, 2009, 14:03 »
Is the MO over for this round?
Logged
Darthfunk
Full Member
Offline Offline
Da funk banana
« Reply #11 on: August 06, 2009, 14:10 »
Quote from: tdk2999 on August 06, 2009, 14:03
Still open however limited units left allocated for this MO.
« Last Edit: August 06, 2009, 14:11 by Darthfunk » Logged
OPPO DV-983H
OPPO DV-980H
tdk2999
Newbie
Offline Offline
« Reply #12 on: August 06, 2009, 15:52 »
Thanks.  Will the moded version still be able to update to newer firmware and still region free?
Logged
Darthfunk
Full Member
Offline Offline
Da funk banana
« Reply #13 on: August 07, 2009, 11:31 »
Quote from: tdk2999 on August 06, 2009, 15:52
The hardware modification will not affect firmware updates.
Logged
OPPO DV-983H
OPPO DV-980H
snnaks
Newbie
Offline Offline
Re: 3rd MO: OPPO BDP-83 + Hardware Modification (CLOSED)
« Reply #14 on: August 19, 2009, 11:34 »
Hi Darthfunk, any news on when shipment will arrive and delivery starts?
Logged
Pages: [1] 2  All Go Up Print
« previous next »
Jump to:
Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC
Scribbles2 design by Bloc | XHTML | CSS
Page created in 0.128 seconds with 17 queries.
Loading...
