Author Topic: handphone from Japan  (Read 3169 times)
Offline crazy777
« on: September 14, 2008, 17:55 »
Does anyone import any handphone (Sharp) from Japan which can be used in Singapore?? ???
Those handphones whereby the screen can be rotated horizontally to make it widescreen.
francis woo
Re: handphone from Japan
« Reply #1 on: September 14, 2008, 18:27 »
Those are CDMAs'.  Don't believe they have GSM for this model............. :P
Offline naglfar
  • Forever Underground
« Reply #2 on: September 14, 2008, 19:42 »
Isn't Japan using 3G network now? Is that still considered CDMA? So if you have a 3G SIM card, will it work with any Japanese phone?
Love your music, not your equipment.
francis woo
« Reply #3 on: September 14, 2008, 20:18 »
Think only Softbank for the GSM iPhone.  Rest of the big guns, Docomo, Vodafone., etc. still on CDMA.  The GSM phones are mostly old fashion types........... ???
Offline crazy777
« Reply #4 on: September 14, 2008, 21:01 »
Those Sharp phones are so cool, i like it when its screen can be rotated. Sadly, no one imports or sells such phone in Singapore :'(
Offline Jedi R
« Reply #5 on: September 15, 2008, 10:44 »
See not touch....
May the force be with you....
francis woo
« Reply #6 on: September 15, 2008, 11:08 »
Can see, can touch, can also buy but cannot be used........................ ;D
Offline crazy777
« Reply #7 on: September 15, 2008, 23:55 »
sigh.... :'(
Offline clitang
« Reply #8 on: September 16, 2008, 13:10 »
In Japan, most of the phone now are 3G. However, it is "sim lock", so it cannot be used anywhere, unless you can break the "sim lock"
Offline apteryx
« Reply #9 on: September 16, 2008, 14:48 »
I think there're people selling it in Singapore cos I saw people using it. It need to be unlock, I think you can find more info in HWZ forum.
Offline crazy777
« Reply #10 on: September 19, 2008, 13:02 »
Thank you very much for the information. :)
Offline media2368
  • Enjoy what you owned in your life!
« Reply #11 on: September 19, 2008, 18:27 »
phone from Japan don't support chinese (if you need it). :)
