Author Topic: Dynaudio Speaker Thread  (Read 1470450 times)
Re: Dynaudio Speaker Thread
« Reply #6450 on: April 30, 2019, 09:02 »
the Evokes look so tiny... anyway all Evokes no stock. whereas all the older models alot.
ProJect Q.
Offline raylowwl
« Reply #6451 on: May 02, 2019, 10:48 »
U can consider getting Hegel 160 or preferably 360, will not break your bank:)
I just listened to the Hegel H190 with the special forty......OMG.....so nice so toxic......but with the Rost....cannot do the same as the 190
« Reply #6452 on: May 02, 2019, 11:17 »
Since you have increased your budget, try the Cambridge Audio Edge A too.
Offline tsi-dsg
« Reply #6453 on: May 02, 2019, 12:22 »
The Hegels have got high damping factor which can control the lows well,with a holographic imaging and a bit of warmth makes them very listenable to any genres of music.
Stereo: Magico S3MK2, Gryphon Diablo 300,
LH Labs The Source SSD w/KECES lps, LH Lab Vidac Signature Dac
Cables:Synergistic Powercell 12se UEF
,Synergistic Galileo cord, Synergistic Atmosphere Level 3 Cord, Kubala Sosna Elation Cord,,Albedo USB,Ansuz Aluminum XLR ,hORNS rack,
Magico Spod, Synergistic Mig 2.0,Synergistic Carbon XOT
HT 5.2.1: Denon X3400H,Magico S3MK2, Elac atmos(front),SVS SB2000(sub), Kef 3005HT(surround),MA CC300(Center)
Source: Nvidia Shield TV, NuBox android
Offline Quest
  • Cyber Dreamer
« Reply #6454 on: May 02, 2019, 13:37 »
Just wondering - at the previous dealer I think it was common to pair Chord and Plinius with Dynaudio and I do know some forumers with this matching that sound good.. but somehow I don't see much interest in this thread for these combos.. any reason?
« Reply #6455 on: May 02, 2019, 13:44 »
Hi Quest, i would believe price to be the main factor. with Chord amps being on the higher tier range.
with the recent trend, most have chosen cheaper options. anyway so much have changed.
ProJect Q.
Offline planet
Offline diesel123
« Reply #6457 on: May 14, 2019, 19:58 »
Anyone have repair their Excite series center speaker X22 before? The tweeter is working but both mids are not working anymore. Maybe a blown crossover?
Offline planet
Offline wusplay
« Reply #6459 on: May 21, 2019, 21:12 »
The look of new Confidence is becoming more acceptable and not as ugly as first sight.
Offline planet
« Reply #6460 on: May 22, 2019, 11:31 »
Dont judge a book by its cover. ;D
« Reply #6461 on: May 22, 2019, 13:44 »
pointless if SG is so much more exp.... :-X
ProJect Q.
Offline etnt
« Reply #6462 on: May 22, 2019, 14:42 »
I wanted to take over your set of focus 260 as spare but kenna rejected by MOF. haiz :'(
Online wechnivag
« Reply #6463 on: May 22, 2019, 19:53 »
Hi BadEnglish,
The speakers are 1.6m apart and my listening position is 1.8m away.
Yes, I do feel my system is noisy and sometime I increase the volume and become harsh as you mentioned.
I am using Plixir 1st gen BAC800 power conditioner. I will get noise analyzer to test it.
Dare I utter the words 'acoustic treatment' in this thread? The symptoms sounds like your space is being acoustically overloaded by the output from the speakers. Imagine a bare and empty bomb shelter.  Doesn't sound very good and can't play any kind of  loud before it gets unbearable....
Among other effects, acoustic treatment helps to dissipate the sound energy in your environment. The measure is the RT - reverberation time. A bare bomb shelter will have very long RT. All this energy and echo bouncing around makes it very fatiguing.
Typically furnishings in a living room - sofa, rug, console, dining table, curtains etc all help to dissipate some energy. But they do not work equally at all frequency. Depending on how bare or furnished the space is, they can be insufficient to handle the sound energy and get overloaded.
The measuring criteria here is ratio of direct to reverberation sound. When the reverberation sound exceeds a certain threshold vs direct sound from speakers, the entire sound falls apart. Typically, this ratio can be improved by listening nearfield, using dipole speakers (which loads the room less), and employing acoustic treatment to manage the energy in the room.
Dedicated acoustic treatment elements can be used and strategically placed to target problematic regions, frequencies and achieve a balanced sounding room.
Hope this helps!
« Reply #6464 on: May 22, 2019, 21:00 »
Haha. I did not get my side surrounds approved too. Cannot expect too much. Taking time off to tweak everything properly.
ProJect Q.
