Author Topic: Dynaudio Speaker Thread  (Read 1401099 times)
Offline soundaudio
  • I love HT
Re: Dynaudio Speaker Thread
« Reply #6300 on: March 13, 2019, 08:08 »
Hi. Anyone bought the newest Dynaudio sub? Can share your thought, am thinking of getting
the subwoofer with my speaker. Thanks.
Offline mousike
« Reply #6301 on: March 13, 2019, 13:29 »
Not to dissuade you but I also considered the same but in the end coupled my C1 with a JL sub and now a happy camper.  :) Just an option...
« Reply #6302 on: March 13, 2019, 13:34 »
seriously 2.1? with C1 ???
when forumers visit me i was playing stereo... they are asking me your sub is on right?  ;D
"ermm nope just stereo"  ;D
ProJect Q.
Offline mousike
« Reply #6303 on: March 13, 2019, 14:45 »
Yup, in a big room with a sub the C1 plays much bigger then a floorstander because of the sub bass it cannot produce. You literally feel the sound :)
Offline soundaudio
  • I love HT
« Reply #6304 on: March 15, 2019, 12:10 »
What is the model of your JL audio sub? I thought JL Audio is more suitable for HT instead of 2 channel stereo.
Offline mousike
« Reply #6305 on: March 15, 2019, 19:18 »
I have the E series. I used the 10 inch for stereo and 12 inch for HT. Either HT or music they sound great and the integration is seamless. None of guess would have thought there is a sub. Happy camper here.
Offline synthesis
« Reply #6306 on: March 15, 2019, 22:45 »
As long as the sub is crossed low enough and not get too excited with the sub gain, any decent sub should do well for music
Offline mousike
« Reply #6307 on: March 15, 2019, 23:08 »
I bag to differ. I have tried at least three other brands but I am only fully satisfied with JL subs. There maybe better or comparable ones but I have yet to try.
« Reply #6308 on: March 16, 2019, 00:06 »
Bro, what makes you think Dynaudio subs are meant for music / 2 channels stereo instead of HT?
May I suggest you audition the brands that you are keen on, and understand how each brand sounds..
Offline demogoblin
« Reply #6309 on: March 16, 2019, 08:16 »
Bro I am using jl audio for stereo. I find it pretty ok
Sent from my G8142 using Tapatalk
Offline nic_wei
« Reply #6310 on: March 16, 2019, 11:09 »
Bro Mousike,
May I know how you connect your sub to stereo?
I have Dynaudio Sub 600 for HT, maybe I can try connect my sub to stereo. :P
Chord Transport, DAC & Multi Channels Amp
Dynaudio C1 Platinum, 200C, S1.4 (Surround), IC17 (Height) & Sub 600
Oppo Blu-ray Player / Denon AVR / Panasonic Projector / OS Screen
Finite Elemente Rack & Accessories / Nordost Cables / Sine Power Distributors
Offline mousike
« Reply #6311 on: March 16, 2019, 12:37 »
Its not complicated because my Stereo and HT is a seperate system. But if you are using one system for both HT and Stereo it can be a little complicated.
Offline soundaudio
  • I love HT
« Reply #6312 on: March 16, 2019, 12:54 »
Connect to pre amp L/R output to sub for stereo?
Offline nic_wei
« Reply #6313 on: March 18, 2019, 16:29 »
If it is too complicated, I better don’t think too much. Only use my subwoofer for HT will do. :P
 I suppose this is the way.  :)
Offline mousike
« Reply #6314 on: March 20, 2019, 12:20 »
Absolutely...these days I am all for KISS - keep it simple stupid!  :D
