Author Topic: Dynaudio Speaker Thread  (Read 1470389 times)
Offline Rachael
Re: Dynaudio Speaker Thread
« Reply #6240 on: December 28, 2018, 01:36 »
I m wondering if the daily amount of hours we played a new pr of spks from beginning affects the number of hours to run in. For instance, 2-3hrs daily, 500hrs to run in, if 8-10hrs daily, it will ran in by 300hrs?
Offline malsound
« Reply #6241 on: December 28, 2018, 06:56 »
It is not the hour per say that determine the hours of final running in time but the content of music or noise. I have had similar experience with my totem forest which a similar driver as dynaudio. I use to play Beethoven symphony No. 9 at about 9 oclock before going for my morning walk/breakfast and that morning exercise for the speaker will shorten the run in time with the rich hamonix content of the music. Other time I just use a cheap transistor slave amp to play tuner at off station(white noise) when I am out for half a day by using its wide band width. A lot got to done not just to run in the surround but mostly to relax the polymer cone.
Offline Rachael
« Reply #6242 on: December 28, 2018, 08:20 »
Apparently, the Forest uses a HiVi driver that is made as a knock off to the Dynaudio woofer. The similarities were the material MSP and the 3” voice coil.
I guess your analogy makes more sense than mine. Thanks for sharing.
Offline acidic88
« Reply #6243 on: January 14, 2019, 10:58 »
Hi everyone, I've just purchased the S40 with Stand 6 and as this is my first Dynaudio, I wonder how I can build up my setup from here onwards. I listen to quite a range of music from jazz, vocals, rock and pop.  I love the sound of tubes but the good ones are really expensive. Rhythm and pace is important to me. So I am contemplating on a tube pre, SS power amp if budget permits.
I'll likely be getting the Avid Ingenium PnP TT this weekend. Also getting a Nagaoka MP-110 cartridge.
Listening area: Living hall, rectangular shape around 7m x 3m
Speaker placement: Along the long wall (old 3rm HDB)
So I guess my real question is, how should I start? With a budget of 2k, I don't mind second hand equipment in the amplification department. Was quite interested in Schiit Freya with Naim NAP100 combo..
Offline blue_starfish
« Reply #6244 on: January 14, 2019, 11:28 »
Check that the pre-amp can amplify the 5mV output of the Nagaoka to a sufficient enough level to drive the power amp. Otherwise you will have to invest in a phono stage. Phono stages add typically around 40dB gain for MM cartridges.
The alternative approach is to get a hybrid (tube pre section with SS power section) integrated amplifier with a built-in phono stage.
Offline deepakvali
  • Trade Count: (+6)
  • La Resistance !
« Reply #6245 on: January 15, 2019, 23:43 »
Does anyone know who would be willing to repair my XEO3? New agent is ripping me off @ $900 for a part (not parts) replacement. This seems like penalising me for not being their day 1 customer
Dynaudio Focus 110 - looking for new home and also other budget cables ;)
« Reply #6246 on: February 11, 2019, 11:45 »
ProJect Q.
Offline mousike
« Reply #6247 on: February 13, 2019, 21:49 »
May I know what was wrong? That kind of money you can rework the xover!
« Reply #6248 on: February 18, 2019, 01:56 »
all right. clean up messy cables and rearranged. itchy backside wanna change something...
ProJect Q.
Offline etnt
« Reply #6249 on: February 18, 2019, 08:30 »
a larger TV. That space can accommodate a much bigger one
Offline deepakvali
  • Trade Count: (+6)
  • La Resistance !
« Reply #6250 on: February 18, 2019, 11:56 »
Any idea where I can rework the Crossover to make it a Passive setup?
What is wrong? I am also not sure but upon power up, you will hear the relay clicking non stop. Assuming it is something power (voltage) related.
Latest update - No replacement part so XEO3 is rendered Useless :(
Offline audioworld2011
« Reply #6251 on: February 18, 2019, 14:16 »
Still no news of the new Dynaudio Confidence series available for audition at local?
« Reply #6252 on: February 18, 2019, 20:02 »
IIRC, the Evoke will be the next model introduced here..
Offline comfortablynumb
« Reply #6253 on: February 18, 2019, 23:05 »
nuts got poisoned by the Special Forty......
Shld I or shouldn’t I?
$3.9k is a lot of moolah for a retiree
Offline deepakvali
  • Trade Count: (+6)
  • La Resistance !
« Reply #6254 on: February 19, 2019, 08:08 »
All depends if your ears are able to discern the value out of $3,900 :)
Cosmetically I am sure you have been convinced.
