Author Topic: Low budget power cords - possible?  (Read 6092 times)
« on: February 07, 2008, 09:43 »
Hi friends
With a budget of < $80 can I get a Power Cord which is warm/ neutral?
Would this be possible?
And is it worthwhile with such a low budget?
Offline pigscanfly
  • I love bulbs!
Re: Low budget power cords - possible?
« Reply #1 on: February 07, 2008, 09:48 »
Hi friends
Perhaps, you want to mention which device you are going to hook it up to.
. Listens to transistor radio .
« Reply #2 on: February 07, 2008, 09:50 »
A couple, a HD DVD player with the figure of 8 type plug and a CD player with an IEC plug.
I would prefer UK plugs, but not fussed.
I just wondered if there is a choice and if there is any acoustic benefit, or am I better off buying better i/c or simply saving it for more CDs...
Offline pigscanfly
  • I love bulbs!
« Reply #3 on: February 07, 2008, 10:19 »
I suggest moving on to US plugs. The UK plugs do have some limitation to the size of cables that you can use unless you go for the expensive Furutech UK plugs.
Power Cords does help in my opinion.
1. A shielded power cord prevents the signal cables from picking up the noise from the power cord.
2. A thicker power cord helps in delivering the required current to the equipment. I see more advantage in using this for amps.
Offline Quest
  • Cyber Dreamer
« Reply #4 on: February 07, 2008, 11:18 »
bro i got some pcocc that im not using now.
can borrow and trial if u want. :)
« Reply #5 on: February 07, 2008, 11:32 »
Thanks, catch up either my place or over pratas :)
Might try it cheers
francis woo
« Reply #6 on: February 07, 2008, 15:27 »
What about the Zion pc that I have given you for testing!!  Another forumer just returned another Zion pc (UK plug) to me, you can try this as well...... :)
« Reply #7 on: February 07, 2008, 15:33 »
Thanks, any figure of 8 types?
BTW the Zion has awesome build quality...
francis woo
« Reply #8 on: February 07, 2008, 15:43 »
Sorry, none.  Have a Furutec and NBS pcs (US plug) lying around though.  Can try if you want....... :)
Offline Quest
  • Cyber Dreamer
« Reply #9 on: February 07, 2008, 16:18 »
think i have converter for the 3 pin to figure 8.. so pretty much can use with anything.
Offline benzx
« Reply #10 on: February 08, 2008, 02:10 »
Hi friends
Pete, the xindak pc03 you took over from me some time ago was the warmest pc I came across so far. Among the budget to mid priced pc I've tried ( belden 19364 & 83803, audioplus pcocc, oyaide PA23, tunami, acrolink P4030), all got its own strength and betters the stock pc, but is less warm than the xindak.  You looking for something even warmer?
« Reply #11 on: February 08, 2008, 04:47 »
Cheers, it was nice but also looking for a cord for my HD DVD player and even toying with changing one for the sub...
Offline ical
  • Vinyl Kills The MP3 Industry
« Reply #12 on: February 08, 2008, 13:31 »
Hi friends
If you can increase your budget slightly, DH Lab will be a good choice for warm sound. It works best on high current component like amp, distributor or conditioner. On cd player, it compromise slightly on detail but give a fuller sound.
http://www.effectiveaudiomod.com/index_products.htm
« Last Edit: February 08, 2008, 13:33 by ical »
P9/ RB1000 | DV-XX2 MkII | PS.30RDT | TecnoWeight | STB-MS/ STB-CM | Clearaudio Matrix | Furutech DF2 | SK-EX | RL30Mk3/ RGC24/ REM8/ RCI3/ RR77 | Isotek Sigmas | CSE RK100 | QC24/ II-40 & nos Tungsol 6550 | SHL5 & Sound Anchor | Solidsteel 5.4 | SCB-RS50G/ TITE35S/ 25MF | Stax 717/ O2Mk1/ 404LE
