Author Topic: Marantz AV amp owners thread - for sharing info tips and comments  (Read 587005 times)
Offline ecpaye
Re: Marantz AV amp owners thread - for sharing info tips and comments
« Reply #2340 on: April 23, 2019, 14:42 »
awww...
<a href="http://www.youtube.com/v/xI---2CtsQk&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/xI---2CtsQk&fs=1</a>
...We pay almost same price or more ex...Yet we get only 1yr warranty?
Bro
If you figured that buying a high end AVR = good sound, sadly that's not true..
It's not a single magic button you can press. If you want that, you need to hire someone and pay him to do it. Otherwise, look around our forum and see the sticky by Bro Desray on Audyssey as a start point. Good luck and enjoy the journey. I'm still learning after 25 years.
Bro, tks for u advised!
Offline ecpaye
« Reply #2341 on: April 23, 2019, 14:45 »
First and foremost, make sure you position the speakers properly and move your seating position away from the rear wall. Then perform your Audyssey calibration properly with all 8 points.
Bro, noted and tks for u advised!
Offline iceblade88
Hi
My SR7010 gives 0.5 second blinking light. I tried resetting by following
Press  power while simultaneously pressing GAME and A-DSX. I unplug everything except the power cable of course.
Is the repair center is Trusty at Kallang? How much would you think the repair bill going to be?
Thanks.
Online petetherock
Offline bluepill193
Updated FW for SR7010 last night, not sure what are the changes.
Offline etnt
most recent changes for 8805 just put stability improvements.
« Reply #2346 on: September 05, 2019, 01:58 »
<a href="http://www.youtube.com/v/XfvWZFAkyGU&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/XfvWZFAkyGU&fs=1</a>
now launched in HK
no wonder Onkyo TX NR696 lups until below $800!
Offline malsound
« Reply #2347 on: October 05, 2019, 13:49 »
<a href="http://www.youtube.com/v/NSTl0XZLDu8&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/NSTl0XZLDu8&fs=1</a>
https://youtu.be/y3RIHnK0_NE
https://youtu.be/FELbmXdS4xM
Online petetherock
« Reply #2348 on: March 01, 2020, 20:19 »
FYI
This is also happening on Denon amps which use vtuner:
https://marantz-uk.custhelp.com/app/answers/detail/a_id/7095
We understand that your vTuner Internet Radio service has changed suddenly.
Here are the current symptoms that we have recognized so far:
On an affected product, when you select “Internet Radio” and select a sub-menu, such as regional stations, recommended stations, the product doesn’t display radio stations, but “Please go to radiomarantz.com* for more info about vTuner’s full access service.”[/q]
  • On radiomarantz.com*, when you press the button on  the bottom, the web site requires for $3 contribution a year for full access to vTuner’s service. For going ahead the MAC address of your device is required. The MAC address can be found in the Setup Menu of your device under Network Info.
As above, vTuner is currently giving you the option of continuing its service without limitation for a small annual subscription fee of $3. If you choose this option, then all vTuner services will be restored within your product upon payment. If you choose not to subscribe, then the vTuner service will be limited to only Added stations from radiomarantz.com* and Recently Played stations. No other stations will be searchable or accessible. This change comes directly from vTuner and Marantz has no control over their policy. We simply carry their service in our products. We again apologize for the inconvenience this has caused and hope we can continue to serve your needs in the future.
* radiomarantz.com is a webpage operated by vTunerAffected models:SR7005, AV7005NR1602, SR5006, SR6006NR1603, SR5007, SR6007, SR7007, AV7701, AV8801NR1504, NR1604, SR5008, SR6008, SR7008NR1605, SR5009, SR6009, SR7009, AV7702, AV8802, AV8802ANR1506, NR1606, SR5010, SR6010, SR7010, AV7702(mk2)NR1607, SR5011, SR6011M-CR603, NA7004M-CR510, M-CR610, NA-11S1, MS7000NA8005, NA6005M-CR511, M-CR611
« Last Edit: March 01, 2020, 20:21 by petetherock »
Offline tan8888
« Reply #2349 on: March 11, 2020, 10:58 »
Anyone know how to remove the marantz flat head pin that lock the top cover at rear center?
The flat head pin have no plus, minus and flower cutting on the pin head.
Thanks.
