Author Topic: $1.5k to 2k for whole HT setup  (Read 17393 times)
Offline jonlee
Re: $1.5k to 2k for whole HT setup
« Reply #15 on: June 22, 2007, 09:40 »
thin = no bass.  Most sats will sound thin.  Small sats maybe even the mids also missing.   ;D
Have u listened to the MS Genie?  About 1.5k for a 5.1 setup.  Not bad for the price, as long as u don't mind it is made in china.  Can audition them at KEC.
« Last Edit: June 22, 2007, 09:42 by jonlee »
« Reply #16 on: June 22, 2007, 09:51 »
Not yet .. no chance to visit KEC cos i went adelphi late evening last night. They actually closed quite early so i only got to visit 3 shops. Will drop by again on saturday to visit more shops!
Yah i've read that the sub is actually very important to the sats. But i'm not sure about PSB subs though. Not much experience with all these.
Online petetherock
« Reply #17 on: June 22, 2007, 10:13 »
Cables can help to some extent
But if you are on a budget, use this to get the best you can afford first
You want satellites, that is a compromise in sound quality
If you are only into HT, the PSB is ok, anyway the tighter ones will cost a lot more
BTW Mirage has a sub around 5-6xx but its cone is 8 inches
Haha thanks for all the bro's reply here.
I'm really getting myself into more trouble by auditing so many speakers. Ever set seems to be getting better, and the price tag keep stressing my budget limit  ;D
I was quoted $1500 for 5 nanosat + PSB sub. Uncle says the original sub that comes with it cost $900 alone. So he suggested pairing up with this PSB sub. Am i overcharged here?
Also, i requested for better cables. So was recommended this $5/m cables ... total for 25m i was charged $100 for it. My concern is is there a need for such cables compared to the normal $1/m kind? how do i identify if its really higher grade cables?
Anyway before i make my purchase, i'll go for another round of audition. Read in other reviews that nanosat sounds thin. What does that means?
Offline dbchoong
  • .. Droid Rulez ..
Re: $1.5k for whole HT setup
« Reply #18 on: June 22, 2007, 10:47 »
Every set seems to be getting better, and the price tag keep stressing my budget limit  ;D
 ;D Better keep within budget - else end up like my colleague who eventually spent over 10 times his original budget for a top of the line M&K + Denon setup. He has no regrets, though. Sounds great!
Offline jonlee
« Reply #19 on: June 22, 2007, 11:39 »
Dbchoong, u bad! :)
« Reply #20 on: June 22, 2007, 11:51 »
This is a very expensive hobby to keep.
But still, its cheaper than playing with cars  ;D
« Reply #21 on: June 26, 2007, 14:00 »
Hi all,
I've decided to get the mirage speakers.
Can anyone recommend me a suitable sub and amp for around $1000?
ps: need a amp can output 100w per channel. Previously was eyeing Marantz SR4001 but realised it only support up to 80w. what is the 'brother' to this model that provides 100w and hdmi out?
Is my budget too little?
Online petetherock
« Reply #22 on: June 26, 2007, 14:04 »
I suggest you stretch to 1.2k and review the Marantz SR 7001 if you like the family sound.
Also do post a review of your mirages in the sats thread, and try them with the amp you are looking at.
KEC has some subwoofer choices you can try them and see what fits your budget
« Reply #23 on: June 26, 2007, 14:12 »
Hi Pete,
Thanks for the prompt reply. 2 question here.
1) For a 100w rated speaker, do i need 100w output amp to drive? Or i can still use a 80w output amp and it will sound fine?
2) Matching of sub to speaker, are they heavily inter-related? Or i should can test the sub alone and if it sounds deep and tight, it should work fine for all speakers.
Cheers.
Online petetherock
« Reply #24 on: June 26, 2007, 14:16 »
Forget the specs bro, main thing is to audition them speakers with the amp and see if it sounds breathless especially during dynamic transients
How to spot these, I have some tips in the 1-1.5k thread.
Same with the sub, integration will allow a wall of seamless sound, with no hole where the frquencies drop off.
SVS is not bad, but not sold locally and may be beyond your budget, see the svs section.
Hi Pete,
Cheers.
« Reply #25 on: June 26, 2007, 23:24 »
Yup i've checked out svs section before. Seems like lots of bros here like them.
I think from the thread cheapest sub already cost $800?
Probably above my budget as i still need to cater for amp and cables .. :(
How about the Wharfedale SW-150 sub? That is award winning one right? I've heard it with the diamond set speakers. Seems great.
Btw, what does 'family sound' means? ;)
Offline dbchoong
  • .. Droid Rulez ..
« Reply #26 on: June 26, 2007, 23:51 »
2 question here.
1) Don't worry about the power rating too much. But more amp power always welcome. ;)
2) You can test the sub alone.
$1k for both amp + sub does limit your choices. If it were me with the $1.2k (top up a bit), I'd choose a cheap amp, good sub route. Maybe try to source a 2nd hand Panny XR AVR for about $400 and splash the remainder for a SVS. But that's just me.
 ;D
Online petetherock
« Reply #27 on: June 26, 2007, 23:56 »
Each brand usually carries their own sonic signature, hence a family sound.
I suggest you choose a few products to audition.
What does ' good' mean to you bro?
A $400 product which is as good as a $1000 one?
Given your budget contraints, keep to it or use as much as you can afford to get something you like, buy less first, say a decent amp and sub, two channels first and spend more when you can, rather than get a product which you feel is a compromise.
IMHO
« Reply #28 on: June 27, 2007, 00:01 »
 ;D
I have been playing around with the figures as well. Was actually thinking to get a amp without hdmi, that should save me some money. Have also been looking for second hand, but not much success though :(
My current idea of setup is like this. Please advise if my thoughts are correct.
dvd player with upscaling --> tv (via hdmi)
dvd player --> amp (through coaxial cable?)
amp --> remaining speakers
I am actually wondering what do i need hdmi input/output for amp? Can u guys enlighten me. I hv connected dvd player direct to tv instead of via the amp. What other purpose does the amp hdmi out serves me?  ???
« Reply #29 on: June 27, 2007, 00:02 »
In fact, i do not mind getting the whole set from 2nd hand as long as the right product comes along  ;D But then, seems like resale market for hifi stuffs not so happening in singapore.
