Author Topic: Pioneer plasma / LED panel thread - share info and tips  (Read 379542 times)
Offline agesis
Re: Pioneer plasma panel thread - share info and tips
« Reply #15 on: June 06, 2007, 19:50 »
What exactly does this setting do?  ???
Any kind souls can share how to check on the timer to see how long the TV have been power on?
Juz want to make sure that Best Denki don't give me a display set...
*** beware this change can muck up your TV ***
technician Special Mode:
> 1.Switch TV off
> 2.Press info & hold button for 3-5 sec
> 3.Left Arrow
> 4.Up Arrow
> 5.Left Arrow
> 6.Right Arrow
> 7.On
> 8.Down Arrow to scroll
> 9.Press "Menu" to switch off special mode.
Live dangerously :)
« Reply #16 on: June 06, 2007, 20:49 »
This enters the service menu
DO IT WITH CAUTION
http://www.avforums.com/forums/showthread.php?t=412331&highlight=427+service+menu
Viewing distance
« Reply #18 on: June 06, 2007, 20:51 »
Offline agesis
Offline agesis
« Reply #21 on: June 11, 2007, 08:47 »
No, I couldn't locate the so-called "info" button posted in the forum.
I tested a couple of times with different button but it's didn't work.  ???
My guess is that the method may only be valid for US or Europe set.
Sure
So have you got your answer and entered the menu?
« Reply #22 on: June 11, 2007, 12:20 »
Another review of the 4270 with settings:
http://www.hdtvtest.co.uk/Pioneer-PDP4270XD/
Offline agesis
« Reply #23 on: June 11, 2007, 15:56 »
Juz received the set on Sat, i tuned down the setting for run-in.
My wife and I watch the DVD "Happy Feet" with the Pioneer DVD player that comes with it. Even with the run-in setting, the PQ is quite impressive. I try to set it to 1080p but got a blank screen instead, managed to set the output on 1080i. The Pioneer tech said that 1080i is the max that can be displayed on 427 using the DVD player.  ???
« Last Edit: June 11, 2007, 16:02 by agesis »
« Reply #24 on: June 11, 2007, 15:58 »
You should check if 1080p is enabled on your Pioneer, some are not.
P
Offline agesis
« Reply #25 on: June 11, 2007, 16:05 »
I read that this set can only accept 1080p24Hz material. No clue if that is the reason why I couldn output 1080p with the Pioneer DVD player.
How do u enabled 1080p on the 427??
P
Offline jeffong
  • You'll Never Walk Alone
« Reply #26 on: June 11, 2007, 16:15 »
I believe the problem is that the Pioneer cannot support 1080p50/60 which your DVD player (assuming it supports 1080p) sends out.  The new Pannys on the other hand support 1080p50/60 but no conclusive proof of 24p support.  Hence, that 1080p24 support on the 427/507 may only be useful if you have a player that can send out native 1080p24 signal which unfortunately is only limited to a handful of BD players right now.  I may be wrong though.
HDR Rulez - UHD-K8500 | Oppo UDP-203 | Zapitti One Mini
Stewart Firehawk 92" | LG 65E6T | Panny 65VT30 | Benq 5700
Denon 8500 | Denon 7200WA | Denon 4520 | SVS PC-12+ | JL E110
UHD BD Titles : Countless
« Reply #27 on: June 11, 2007, 16:17 »
Jeff is right,
Actually I meant your DVD player, the panel accepts 1080p 24 fps, but I don't think your DVd player outputs that, probably 1080i max :)
Offline jeffong
« Reply #28 on: June 11, 2007, 16:22 »
The free player given by Pioneer for the PC show is the DV400 which does support 1080p output but most likely at 1080p50/60 modes only.  No choice lor, can always sell your Pioneer and get the Panny instead.  ;D
Offline rahul
  • Gooner
« Reply #29 on: June 11, 2007, 16:28 »
1] petetherock - 507 XG (bought as a display set - <5k 5/07 )
2) wentworth - 427 Taking delivery this coming Sat.
3) chubbyman - 427 (delivery end of the month)
4) agesis - 427 Taking delivery this coming Sat
5) bloob - 427, installed 2 months ago
6) Scoobydoo - 427 installed in Oct 06
7) Rahul - 427 (Jan 2007)
CDP: NAD C540    Plasma: Pioneer 427 AVR: Marantz SR5600     DVD: Oppo 981
Power Amp: Rotel 1075         Blu-Ray: Playstation 3  TubeAmp: Cayin MT12
Speakers: Monitor Audio RS6/LCR/B1   Sub: SVS SB12+ , REL Strata II
Study HiFi setup
- Lavry DA11, Densen DM30, Audiolab 8000P, Dynaudio Focus 220 MKII, Kimber 8TC
