help!!Using pliers, flat head screw drivers, pen knife and the plastic centre plug just wun come out!!It seems that that piece of plastic plug is moulded to the base plastic cover.Anyone did this same thing before??
Hiya KS,Actually I have posted a solution for this sometime back which by the way I learned from here.For your benefit, here it is again...first get a small screw, one of those for wood with a sharp point , then screw this in about 1/2 to one turn, then use a plier to pull the screw head out, if you do it right, the plastic piece will come out together with the screw. Then repeat with the others... Viola virgin hole ready for your bananasRegards.Dirtrun
synthesis' picture show the after treatment. just the round caps
