Author Topic: Help on Yamaha RXV730  (Read 1608 times)
Offline Calvin83
  • _h|de_
    • My DVD Profiler
« on: June 04, 2002, 19:25 »
How do I go about getting Dolby 2.1 to work? Whenever I play Dobly 2.1, I can only switch between Prologic or Prologic II? I can't seem to find how to go about disabling Prologic/Prologic II on the receiver. Can someone kindly enlighten? Thank you.
"Go ahead and use my wings, spider.
But even you, who is yet to know the hardships of flying,
Will someday realise.
That you were only flying within someone's hand,
And that you were calling that freedom..."
Re:Help on Yamaha RXV730
« Reply #1 on: June 04, 2002, 21:57 »
On my yammy 2200, turn off "effects" to listen to plain stereo.
Btw, Dolby 2.1 is a term never used. The "2.1" numerology indicates "2" discrete channels + a "0.1" bass channel.
Look up ur manual on how to turn on/off effects.
Good luck!
Offline Calvin83
  • _h|de_
    • My DVD Profiler
« Reply #2 on: June 04, 2002, 22:12 »
Thanks for the correction, so I supposed it's called Dobly Surround?
Hmm, what is the meaning of stereo? It means only the 2 main speakers right? So when I change to stereo mode, it is Dobly Surround? Actually I knew of the stereo mode, but I thought maybe there's another mode for Dobly Surround. ???
