Author Topic: Which is a better choice ??  (Read 2679 times)
Offline jowy85
« on: June 03, 2002, 00:45 »
there are 2 HTS in my mind ...
Sony HT-K215 , $499
Key Features
 24-Bit DTS
 Dolby Digital Decoding
 Dolby Pro Logic Decoding
 Cinema Studio A/B/C Mode
 25W RMS x 5 Channels
Features
 Virtual Multi Dimension Mode
 2 Optical Digital Inputs
 2 AV Inputs
 5.1 Channel Inputs
 Colour -Coded Speaker Terminals for Easy Connection
 Remote Control
 5cm Full Range Drivers
 Acoustically Loaded Bass Reflex
 16cm Cone Woofer
 Power Output:50W
Yahama TSS-1 at $299
Key Feature
-48W Total Power (6W per satellite x 5, 18W for subwoofer
-Frequency Response 40Hz - 20 kHz
-Drivers 2" cone for satellites, 5" driver for subwoofer
-5.1 channel full scale; 4.1 channel surround; stereo
-2" Digital inputs ( 1 optical, 1 coaxial); 2 analog inputs
-Master volume, individual levels for center speaker, effects speakers, subwoofer; full-mute
so which is a more worth it HTS as there a $200 difference between for the both HTS .
thankz guyz
Offline HT
Re:Which is a better choice ??
« Reply #1 on: June 03, 2002, 12:00 »
Hi:
For close to or exceeding AV amp performance, do consider the Creative Inspire 5.1 Digital 5700!!
DTS, DD, Designed by cambridge soundworks, check out current issue of WHAT HI FI.
Also features the new SLAM subwoofer !!!
The 5700 wipes out both the sony and yammy here.
HT ;D
duckling
« Reply #2 on: June 03, 2002, 14:44 »
Hi:
HT ;D
The 8 inch woofer you see is in fact a passive radiator.  Behind that radiator is a 5 inch woofer that is the actual power behind this sub.  As such, the 5 inch woofer explains the mediocre bass performance of the system.
Check out the review on Inspire 5700 here: http://www.penstarsys.com/Reviews/speakers/creative/inspire_5700/
Offline jowy85
« Reply #3 on: June 03, 2002, 23:47 »
How much was the creative set ??and is it worth the price ??coz i looking for HTS which is value for $$$
thanzk
Offline lksey
« Reply #4 on: June 04, 2002, 08:45 »
for a simple system which'll give u the most bang for the moolas, go for the Yamaha.  but i'm assuming that u'll be using it for dvdplayback on the PC.  my brother's using it for his bedroom, and it sounds pretty decent - just that one gotta sit in front of the monitor to enjoy the show.
for very limited space, ie, usage as desktop speaks, very good buy
紫 霞:我知道有一天他會在一個萬眾矚目的情況下出現,身披金甲聖衣,腳踏七色的雲彩來娶我!
至尊寶:曾經有一份真誠的愛情擺在我的面前,但是我沒有珍惜,等到了失去的時候才後悔莫及,塵世間最痛苦的事莫過於此。如果上天可以給我一個機會再來一次的話,我會跟那個女孩子說"我愛她"。如果非要把這份愛加上一個期限,我希望是一萬年!
Offline HT
« Reply #5 on: June 04, 2002, 14:21 »
Unlike the Creative 5700 or the Sony, the yammy has GOT NO REMOTE.
Also if you are looking to pair it with Sound Blaster 5.1 cards, the 5700 features the most input connectivity here
Dual analog, DIN for SB Live/Audigy, Optical, Coaxial...
Acoustics verfified by Cambridge Soundworks.
HT ;D
Offline jowy85
« Reply #6 on: June 04, 2002, 14:49 »
i will playing this yamaha TSS-1 with samsung m108 .and to me remote is not that important ....so juz wanne ask should i put in $200 more to buy sony ones ?
