Author Topic: Wat combo u use 4 ya HTS?  (Read 3651 times)
Offline Phil
  • HT addict
« on: June 01, 2002, 10:24 »
Lets c waz e trend is like in extreme place.
Phil
duckling
Re:Wat combo u use 4 ya HTS?
« Reply #1 on: June 01, 2002, 18:27 »
Currently, I am using A/V Receiver and DVDP. Will be switching to HTPC soon. I must say, once you see HTPC in action - there is no turning back to DVDP.
Just my personal opinion. :)
Offline dethangel
    • Kryogen Innovations
« Reply #2 on: June 01, 2002, 20:16 »
Hmm ... true HTPC is the way to go ... esp with current DiVX encoding flexibilities.... and dropping HDD prices... you
guys shld know what i'm talking about :P
PC which is hooked up to the TV / Panny projector  ..... sound is hooked up to a Yammy receiver.
Result: Priceless? :P
« Last Edit: June 01, 2002, 20:20 by dethangel »
Offline quekky
  • Lift your music
« Reply #3 on: June 01, 2002, 23:46 »
if i got the money and place....
HTPC + prepro + digital eq/x-overs + DACs + powers + a few 3 guns ;D
duckling
« Reply #4 on: June 01, 2002, 23:49 »
I think you've over do it. ;D
Offline Phil
  • HT addict
« Reply #5 on: June 02, 2002, 00:00 »
Juz a clarification regarding HTPC..
Its oni worthwhile 2 go HTPC if they r couples /w projector?? Or oni those projector with progressive scan?
Phil
Offline quekky
  • Lift your music
« Reply #6 on: June 02, 2002, 00:07 »
it's just my dream for the moment that i dun think will come true ;D
« Reply #7 on: June 02, 2002, 12:02 »
HTPC actually very good to pair it with a pj. HTPC can tweak to be pixel perfect.
To use with TV, any DVDP is good enough. TV can't do pixel level adjustments since its not designed like that.
joamonte
« Reply #8 on: June 02, 2002, 12:46 »
HTPC is good in PQ....
but the sound quality might be consider very weak if compare 2 a good DVDP as most of the sound card was not design 4 5.1 HT but 4 game..
unless of couse u willing to spend $500 and above to get a HI-end sound card,and with it your PC might cost u $1800 and above---not 2 forget u also need a good Display card n DVD ROM...
even use the digital out if u compare careffully u will notice the DVDP will be quite better in term of detail,dynamic  and trasparancy because of HTPC poor S/N ratio...4 me,i think the sound quality is as important as the PQ cos i also like to watch live concert thru my HT.... ::)
lasty,the FAN NOISE >:(...not 2 forget the projector already got 1 fan inside...now  ::) if u also like overclock u PC....then... :-\
Offline lksey
« Reply #9 on: June 02, 2002, 14:31 »
A good video card for HTPC need not be expensive.  Unless u're trying to build an all-powerful PC for 3D gaming and HT, then u need not shell out lotsa $$ for the videocard.  Eg, a first generation Radeon 7500 provides very good PQ for DVD.   And a DVD rom drive is not expensive - $75 to $120.
To derive good quality sound output, yup, most prolly gotta spend about $300 to $500 for a soundcard (which is why i'm organising the MO for M-Audio Delta 410).  The sound quality may not be that significantly different from a DVD player, if u're using a good soundcard. In fact, i wld think that the sound quality from the latter wld sound better than a sub $1k dvdplayer.
Fan noise can be negligible if u use Intel CPUs.  And if u're using the PC for HT purpose, think there's no need to O/C the CPU.
The cost of $1800 u've estimated is for a good gaming/HT PC.  & I wld think its not very fair to compare the PC's total cost to that of a standalone DVD player, since the PC is gonna perform more than just DVD playback.
紫 霞:我知道有一天他會在一個萬眾矚目的情況下出現,身披金甲聖衣,腳踏七色的雲彩來娶我!
至尊寶:曾經有一份真誠的愛情擺在我的面前,但是我沒有珍惜,等到了失去的時候才後悔莫及,塵世間最痛苦的事莫過於此。如果上天可以給我一個機會再來一次的話,我會跟那個女孩子說"我愛她"。如果非要把這份愛加上一個期限,我希望是一萬年!
Offline Phil
  • HT addict
« Reply #10 on: June 02, 2002, 15:02 »
A Q 4 those /w reciever & poweramps combo..
Is it 4 ya front or all channels?? Have u try 2 biamp under such config??
Phil
duckling
« Reply #11 on: June 02, 2002, 16:58 »
I fully agreed with Iksey.
BTW, I guess the Radeon 7200 would be sufficient for HTPC - w/o fan - reduce noise. Or can I say the 7500's little fan does not make too much noise / no noise at all?
