Author Topic: hunting for budget dts amp  (Read 2054 times)
Offline cableguy
« on: May 31, 2002, 21:28 »
Was wondering how much does a DTS amp cost for budget user.Where??Pls reply ::)
duckling
Re:hunting for budget dts amp
« Reply #1 on: May 31, 2002, 22:30 »
What is your budget?
Offline cableguy
« Reply #2 on: May 31, 2002, 23:33 »
amp less than $500
Offline Phil
  • HT addict
« Reply #3 on: June 01, 2002, 09:49 »
amp less than $500
Most entry receiver from Denon, Marantz, Yamaha will fit ya budget.
Phil
duckling
« Reply #4 on: June 01, 2002, 18:33 »
I suggest you go to KEC, it's a good shop to begin with.
