Author Topic: Any demo discs to test the speakers ?  (Read 2561 times)
Offline ifiron
« on: May 20, 2002, 16:18 »
Hi Guys,
Any recommendations ?
A+, Network+ , Certified Lotus Specialist
Re:Any demo discs to test the speakers ?
« Reply #1 on: May 20, 2002, 16:29 »
Test what of your speakers?
Good disc to get would be XLO/Reference Recordings Test & Burn-in cd. Its rather expensive for a cd, but can be found in MWH. Good for general setup, burn-in and check.
Denon Hi-Fi check cd is also a good test cd, not to mention chesky's hi-fi test disc & home theater check disc ( can't remember the exact title, but u'll know when u find it)....... good for listening to the finer points of audiophile listening and HT setup respectively.
For straight bang, smash and crackle dvd, then there is just too many to recommend.
Offline ifiron
« Reply #2 on: May 20, 2002, 16:45 »
Hi Jag,
Thanks for the response. Actually, I am still a newbie in this area of audio. If I want to test the Wharfedale Diamond setup, what do you recommend ?
duckling
« Reply #3 on: May 20, 2002, 17:02 »
Hi ifiron,
any you talking abt Home Theater Setup or HiFi Setup?
You may refer to this post: http://www.xtremeplace.com/yabbse/index.php?board=11;action=display;threadid=707;start=0
« Last Edit: May 20, 2002, 17:23 by duckling »
Offline ifiron
« Reply #4 on: May 20, 2002, 17:28 »
Hi Duckling,
Once again thanks for your help :) ...
Btw, I am thinking of going down to hear the Wharfedale Diamond Series, was quoted $1059 for the whole package by Par Audio. What do you think of the price ?
duckling
« Reply #5 on: May 20, 2002, 17:55 »
Hi Duckling,
I guess you ask the wrong guy... ;D, cos' I dun like the sound of Wharfedale speakers.
