Author Topic: Help: Repair Marantz CD63 MKII KI Signature  (Read 651 times)
Offline kypay
« on: September 14, 2020, 22:31 »
Hi,
The CD door fail to open :(.
Can advise me where/ who can fix this problem? Uncle Lim retired already.
If DIY, which level and shop in SLT to get the parts?
Thanks,
Ah Pay
Offline Goldberg
  • Enjoy your music for yourself & not others.
Re: Help: Repair Marantz CD63 MKII KI Signature
« Reply #1 on: September 14, 2020, 23:16 »
You can contact Alfred. I send my Marantz SACD player for him to repair. Reasonable price. I found him in Carousell.
https://carousell.app.link/YD8LLPDdM9
Marantz SA-7S1 (Reference SACD Player)
Marantz NA-11S1 (DAC/Reference Network Player)
Marantz SC-7S2 (Reference Pre)
Karan Acoustics KAS400 (Stereo Dual Mono Power Amp)
Focal Scala Utopia (Speakers)
NBS & Siltech (Cables)
Jade Audio IsoGen2 (Isolation Footers)
PLixir BAC Elementa 2500 (Power Conditioner)
NBS Mine (Power Conditioner)
Offline HiFi
« Reply #2 on: September 15, 2020, 00:28 »
Yes Alfred is the guy.
ARC Ref6, ARC PH9, ARC Ref160S, Nottingham Ace Space deck 294 with 12-inch space arm, Clearaudio Syncro Speed Controller, VDH DDT-II Special phono cartridge. CEC TL-2X, Audio Note DAC 4.0X, Benchmark DAC1 for Oppo 103D and mediabox player, Kenwood tuner, Sonus Faber Cremona M, VPI Record Cleaner, Shunyata power cables, Geortz II speaker cables, Audio Note VX interconnects. Using Plixir Elite BAC 3000 balanced power conditioner with full Furutech sockets and Plixir Statement balanced power cable
Offline dm
« Reply #3 on: September 15, 2020, 08:19 »
Had a very bad experience with Alfred, will not have any dealings with him anymore.
Bought a used valve CDP (its European made, not cheap player) from him and later realized the cdp dac has been bypass to a cheapo, less than $10 china made dac.
Online YANG
« Reply #4 on: September 15, 2020, 08:34 »
Marantz n Denon are not very uber high-end makes. Hence, from the fella's ad, u can presume that he'll not be using uber high-end components for repair oredi...
Offline kypay
« Reply #5 on: September 15, 2020, 11:29 »
Thanks for all the advice. He quote $65 with 2-3 days downtime.
Discover yesterday, the CD door can manually pull out slowly, put CD, slowly push in. It is still able to play without skipping.
Offline HiFi
« Reply #6 on: September 15, 2020, 11:50 »
what is bypass??  did he tell you that the original dac was faulty?
Offline watchdog
  • Trade Count: (+6)
« Reply #7 on: September 15, 2020, 14:32 »
If you open the player, you will find that the tray open and close mechanism consists of a gear, plastic wheel and a rubber band. If the gear and plastic wheel are in good condition, it's the rubber band that has turned hard or stretched.
https://www.aliexpress.com/item/4001146267135.html?spm=a2g0o.productlist.0.0.1c41329cBuPmmB&algo_pvid=112a03db-21ad-4633-ab51-11d06ad06476&algo_expid=112a03db-21ad-4633-ab51-11d06ad06476-0&btsid=0bb0623b16001515306502380e168a&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Less is more !
Offline lieu9310
« Reply #8 on: September 17, 2020, 14:59 »
the rubber belt is gone... you can try Joe (92950079)... he will do it on the spot for you ...
Offline wyx03
« Reply #9 on: September 18, 2020, 09:21 »
Have had bad experience with Alfred too. Bought a pair of used speakers and found it to be broken when tested at home.
There was obvious sign of touch-up to 'hide' the defect  >:(
