Author Topic: Restarting my hifi journey  (Read 5025 times)
Offline kinger
Re: Restarting my hifi journey
« Reply #45 on: September 15, 2020, 21:33 »
Yes only IOS user for airplay.
Does airplay support hifi flac lossless cd quality streaming?
Offline Djblackfm
« Reply #46 on: September 15, 2020, 22:45 »
http://geekout.io/index_files/The_truth_about_AirPlay_audio_streams.html
Hope the above link helps.
Offline kinger
« Reply #47 on: September 15, 2020, 23:00 »
Offline zephyr11
« Reply #48 on: September 16, 2020, 08:39 »
The soundstage is sedap! 😀
using airplay was also shared to me by DJQ, he told me to try cos i had some lag with 4stream app. i only use the app when i use the dlna function to pull music from my pc in the other room.
all works quite well now.
Offline kinger
« Reply #49 on: September 20, 2020, 19:09 »
Where is the dlna function in the 4stream app...i can't seem to find it?
Offline kinger
« Reply #50 on: September 20, 2020, 22:03 »
got it...via the router and auto-detected by the nord...
Offline kinger
« Reply #51 on: September 20, 2020, 22:24 »
In summary on the Nord connect pro V3 and the Ares ii...
The Nord is a cost effective streaming player without the colorful display like other players. It is a dull looking set with wonderful remote controls from the mobile phone via app like 4Stream (read no physical remote control needed).
The limitations of music streaming services like deezer which only streams hifi (CD) quality to their specific hardware manufacturer like Node 2i, has restricted me to consider the 2i initially. Here came along this half price Nord option to stream using apps like 4Stream (built-in login for deezer) or Double Twist Pro (paid app) for android airplay option has fulfilled my music enjoyment with very good quality in term no lagging in using the apps and a coaxial output (44.1khz) to the external dac. Can't comment much on the sound quality of the Nord as it is processed by the Ares ii dac.
Ares ii - Analog, Clear, Separation, Soundstage are the keywords to describe its strength. NOS or OS is available for tuning to your sound liking. Weakness it may sound too airy to someone who like analytical sounding dac.
onwards for the amp search...
Great help from bros below on information they had shared...
Link from Bro Z dust cap/pwr amp thread...
you can experiment.
Put your amp on 1/4 power.
Turn your pre amp way higher to achieve your usual listening level.
You will notice that the vocals now sound super concentrated in the middle and come forward from the soundstage. This is an effect of audio signal saturation in the signal path (a kind of dynamic compression).
Some people actually like this effect....
As the Nord output is quite high, I set the volume to 3/4 and the vocal saturation issue is resolved...
Thanks all.
« Last Edit: September 21, 2020, 06:55 by kinger »
Offline zephyr11
« Reply #52 on: September 21, 2020, 08:25 »
means you selling ares ii?
 :o :o :o
Offline kinger
« Reply #53 on: September 21, 2020, 09:01 »
 :o :o :o
no lah...ares ii is a keeper...i haven't got a better amp....is using a basic denon integrated now...
if selling ares ii, you wana buy? i sell at $2xxx....whahahah...run-in condition
« Last Edit: September 21, 2020, 09:06 by kinger »
Offline kinger
« Reply #54 on: September 21, 2020, 13:49 »
Teaser......
Hi Bro S, how does this amp sound so far?
« Last Edit: September 21, 2020, 13:55 by kinger »
Offline synthesis
« Reply #55 on: September 21, 2020, 16:13 »
So far so good. Have a listen so you can judge better
Offline zephyr11
« Reply #56 on: September 22, 2020, 11:11 »
jin funny hor...
Offline kinger
« Reply #57 on: September 22, 2020, 11:21 »
jin funny hor...
Sony Sony, pls Aiwa (in hokkien)?
haha   :D
Offline Desperado
  • Don't Worry Be happy
« Reply #58 on: September 22, 2020, 19:34 »
Hi, Can your Nord stream DSD to Ares II? and with which connection?
Thanks.
Offline kinger
« Reply #59 on: September 22, 2020, 19:50 »
Thanks.
I don't think so...the coaxial output from Nord is at 44.1khz into Area ii
