Author Topic: Restarting my hifi journey  (Read 5660 times)
Offline ginamos
Re: Restarting my hifi journey
« Reply #30 on: September 11, 2020, 14:53 »
I am still a beginner in HIFI.
This new norm of Working From Home made me search for a stereo integrated amp to  improve the sound quality of music playback while working.  I stumbled into this youtube channel that really convinced me that an amp must not only sound good but also should have good build quality inside and out.  On the guy's list, Yamaha's amp impressed me so I got A-S1200 once it is available.  Sound quality is great for my ears and build quality is fantastic in its price point.  'Really have to audition to make sure the sound suits you though.  I got Node 2i as a source to checkout Tidal MQA.
https://youtu.be/QXvIBHv4bsg
Offline kinger
« Reply #31 on: September 12, 2020, 21:01 »
Collected & unboxing Ares ii...
Brotherhood shots with Nord...
« Last Edit: September 12, 2020, 21:03 by kinger »
Offline synthesis
« Reply #32 on: September 13, 2020, 07:31 »
By the time you get the amp, you really need to budget for your speaker replacement  ;D
That is the next bottleneck
Offline kinger
« Reply #33 on: September 13, 2020, 11:25 »
Quote bro Z words of wisdom...要花钱的升级, 是可以等地
« Last Edit: September 13, 2020, 11:44 by kinger »
Offline synthesis
« Reply #34 on: September 13, 2020, 14:06 »
Cannot wait..... That's likely to be the biggest improvement   ;D ;D
Offline kinger
« Reply #35 on: September 13, 2020, 14:11 »
 ;D wahaha
Offline kinger
« Reply #36 on: September 13, 2020, 15:56 »
The AE301 not bad lah...compared to Usher 520 or Q Acoustics 2010...
« Last Edit: September 13, 2020, 15:58 by kinger »
Offline jerome_the_lang
« Reply #37 on: September 13, 2020, 17:15 »
anybody in this thread playing vinyl...?
Offline zephyr11
« Reply #38 on: September 14, 2020, 16:16 »
i think these are gonna be quite sufficient in this current situation, if you don't plan to add more sources.
if you had come from no dac to ares ii, i think you will not have to upgrade for a long time.
give you another one;
"just remember, the only person who needs to like the music is you", stolen from youtube.
Enjoy the music!
yes, me, but i also newbie, if you got qn, just post. here a lot of pros, just if they have time to reply.
Offline kinger
« Reply #39 on: September 14, 2020, 17:33 »
Enjoy the music!
The ares ii is indeed a surprise...analog sounding like vinyl with much clarity and separation. quite "zai" (stable) sounding DAC...worth it in every cents
The nord using 4stream app is flawless too...continuous music playback without interruption...the songs selection and loading are very fast too using lan cable connection.
Only question on nord/4stream is whether do they do FLAC - 16-bit 1,411 kbps Lossless, CD quality streaming as i have just changed my subscription to Deezer Hifi...
Offline zephyr11
« Reply #40 on: September 15, 2020, 08:45 »
agreed on the ares ii, that's what i felt when i first turned it on, goosebumps!
i don't use the 4stream app, and use airplay instead, you could give it a try.
Offline kinger
« Reply #41 on: September 15, 2020, 09:32 »
Is airplay for IOS only? I'm using android phone...
Offline kinger
« Reply #42 on: September 15, 2020, 10:06 »
Need to pay...
Offline Djblackfm
« Reply #43 on: September 15, 2020, 10:10 »
Yes only IOS user for airplay.
Offline kinger
« Reply #44 on: September 15, 2020, 10:56 »
The soundstage is sedap! 😀
