Author Topic: Desktop DAC Question  (Read 3328 times)
Offline t1m3ch453r
  • Assumption is the mother of all fuckups
Re: Desktop DAC Question
« Reply #30 on: August 20, 2020, 09:34 »
I think the limitation is in the speaker/internal amp itself. Is there any tone control? This may have bigger benefit for small speaker
No tone control unfortunately. Just loudness ;-)
If, as you say, the speaker is the limitation then well I am done! Cannot see myself changing these speakers anytime soon :)
Offline Gondon72
« Reply #31 on: September 08, 2020, 08:46 »
Does anyone has any experience on these 2 integrated amp? :)
1. Denon PMA-60
2.  TEAC AI-301DA-X
3.  Cambridge Audio ALL IN ONE
Thanks.
« Last Edit: September 08, 2020, 20:07 by Gondon72 »
Offline zephyr11
« Reply #32 on: September 10, 2020, 09:21 »
think i suggested to someone else, propping up your speakers might help more than upgrading your amp/dac.
and i honestly think the basic isoacoustic ones are best bet for the money. ($100+) though they are likely not the prettiest.
Offline Gondon72
« Reply #33 on: September 10, 2020, 09:49 »
Yes, i think i also read your post somewhere.
I got the SMSL AD18 recently but was not really happy with it as the temperature is quite hot when touching it even when the aircon is on.
Offline t1m3ch453r
« Reply #34 on: September 14, 2020, 13:20 »
Could you elaborate on the propping up the speakers part please? Interested in trying this out.
Offline t1m3ch453r
« Reply #35 on: September 14, 2020, 13:21 »
1. Denon PMA-60
2.  TEAC AI-301DA-X
Thanks.
I am using a Myryad Z120 - sound signature wise probably close to the Cambridge Audio, and I love that.
Offline t1m3ch453r
« Reply #36 on: September 14, 2020, 13:24 »
An update. I did find the Modi and got it for a couple of hours to play with. However, the effect was like earlier i.e. not much of an improvement. And well the wife did put her foot down that I am not to spend any more money on the setup in terms of changing the components.
So I decide to see if I can upgrade the audio path. I added the iSilencer+, changed the USB cable to an Anker cable and the 3.5mm connect to SKW. Perhaps just placebo, but I do find this has improved the soundstage and brought the instruments and vocals more forward. The most pronounced effect is on fast paced music - where I used to "feel" that my speakers were not completely keeping pace, but now I have no such complaints.
Think I have reached the end of my road on this one! At least till the bug strikes again :)
Offline zephyr11
« Reply #37 on: September 14, 2020, 16:02 »
this.
https://isoacoustics.com/iso-155-isolation-stands/
i started with using foam pads to tilt up the speakers, but eventually got these, and WOAAAAAAAAAH.....
i honestly think this is the best upgrade for nearfield listening...
Offline kinger
« Reply #38 on: September 14, 2020, 17:40 »
same same but different...haha
Offline t1m3ch453r
« Reply #39 on: September 14, 2020, 18:21 »
this.
Thanks a lot. Will check this out.
Offline synthesis
« Reply #40 on: September 14, 2020, 23:13 »
In case you want to start over, it's probably better and more flexible using passive speaker.
Here's my office setup using small enough speaker and inexpensive tiny bluetooth amp with tone control. Very enjoyable
Offline zephyr11
« Reply #41 on: September 15, 2020, 08:34 »
there's a gentleman on carousell selling, brand new for decent prices.
Offline zephyr11
« Reply #42 on: September 15, 2020, 08:37 »
at first glance i thought those were boenicke!
can i ask what are those? they look pretty good, i suppose they sound quite decent too!  :o :o :o
Offline synthesis
« Reply #43 on: September 15, 2020, 08:46 »
My home made speaker. Took inspiration from Boenicke W5. Same woofer but different fullrange driver (Boenicke driver is cheaper :P )
Offline zephyr11
« Reply #44 on: September 17, 2020, 10:27 »
woah, that statement is very disturbing, boenicke already very ex...
 :o :o :o
