Author Topic: Introducing MYSTJ Hifi Rack from Taiwan  (Read 459 times)
Offline Sound Affairs
  • PLiXiR Balanced Power Products.
    • Sound Affairs
« on: August 11, 2020, 11:26 »
MYSTJ Hifi Racks
Dear all, we will like to introduce the MYSTJ Hifi Racks from Taiwan.  Ultra-rigid, solid, immovable across all the models yet selectable in height they represent the best value and performance ever!   Specs below:
General Information and features :
Wood Platform Material : 1.5 inch Multi-Layer Birch plywood.  Multi-layer to damp vibrations across all axis.  Thickest in the market.
Wood Platform Finish : Natural Birch, Walnut, Black (only for RX series).  Furniture grade finishing that is lush looking, durable for years and fits all types of home d├ęcor.
Each level/tier is spiked individually with adjustable levelling to isolate vibration from other tiers in the stack.
MYSTJ HS Series.
Value for Money.  Support column Extruded from 1.5 inch diameter STEEL thick hollow in black color.
Layer Height available (Internal height for equipment) :  10cm / 20cm / 26cm / 31cm.
Wood finish :  Furniture grade Birch and Walnut.
Weight : 11kg per layer.
Each Tier/Level Price SGD$475 Fixed.
MYSTJ CMS Series
High Performance.  Support column machined from SOLID CORE 1.5 inch diameter Stainless Steel in natural finish.
Layer Height available (Internal height for equipment) :  7cm / 15cm / 21cm / 25cm / 31cm / 35cm.
Weight : From 12kg (CMS-7cm) to 22kg (CMS-35cm).
Each tier / Level Price.  From $600 (CMS-7cm) to SGD$910 (CMS-35cm) Fixed.  Contact us for the exact price for each level height.
MYSTJ RX Series
Ultimate Flagship Performance.  Support column machined from SOLID CORE 1.5 inch diameter Stainless Steel in natural finish.  In additional, machined solid Steel cross-brace structure with integrated ceramic ball bearing footer.  Platform rests freely and stressless on the cross-brace structure with additional vibration isolation in the horizontal plane.
Layer Height available (Internal height for equipment) :  7cm / 16cm / 20cm / 26cm / 30cm / 36cm.
Wood finish :  Furniture grade Birch, Walnut and black.
Weight : From 19kg (RX-7cm) to 32kg (RX-36cm).
Each Level Price.  From $1580 (RX-7cm) to SGD$2000 (RX-36cm) Fixed.  Contact us for the exact price for each level height.
Samples of all 3 series are available for view at our showroom
Thank you.
James.
Tel : 9694 9704. (10am to 6pm) Monday to Saturday.  Strictly by appointment basis.  Thank you for understanding).
James Soh
Sound Affairs Pte Ltd
email : sales@mysoundaffairs.com
www.mysoundaffairs.com
110 Lorong 23 Geylang.  #06-03 Victory Centre.  S388410
PLiXiR Balanced AC Power Conditioners/DC Supplies and Cables.  Made in Singapore.
Swiss PSI Active Bass Traps and Active Speakers
OPPO Digital Distributor and Product Modifications Centre.
DAC and Digital source modifications with True Femto Clock modules.
Other Brands : MELCO, Black Cat Cables, Weiss Digital, Benchmark, Bfly, Frank Ultrabank Products UB25000
