Author Topic: Cheap Rear Speakers  (Read 1326 times)
Offline htng
Re: Cheap Rear Speakers
« Reply #15 on: June 24, 2020, 19:57 »
Def tech
Offline exclusive
« Reply #16 on: June 25, 2020, 09:21 »
Def tech
same. def tech pro1000 and 800.
however, egg is more beautiful
7.2.4 [DENON X3600H,MINIDSP DDRC 88A/2x4HD, ANTHEM MCA 3 POWER AMP POWERING KEF LS50 LCR C/W GRILLES,ADA MPA 5 POWERING DEFINITIVE TECHNOLOGY PROMONITOR 1000 AS SURROUND ON SANUS STAND,DEFINITIVE TECHNOLOGY PROMONITOR 800 HEIGHTS, RYTHMIK FV15HP+F15HP]
LG OLED 55C7
Zidoo z9s w/ ext HDD SATA
« Reply #17 on: June 25, 2020, 10:32 »
Line up for sat speakers...
How about B&W M1? I used def-tech before but replaced it with M1 for my 3 channels up there.
Give a clean surround effect for the Atmos ceiling.
Offline Soul108
« Reply #18 on: June 25, 2020, 15:11 »
Check out the used hts3001se series. They are pretty good for price. And the angling flexibility is super impressive if your mlp is at a tight angle. The e301 (I had a pair for 1 month) can't tilt that much...
A used pair is abt 100+
Plus if u are using KEF speakers as your LCR, then better to use back KEF for surrounds for the timbre to be more similar
Cant find so cheap on the internet
Sent from my VOG-L29 using Tapatalk
