Author Topic: Projector pink hue  (Read 686 times)
Offline zac110
Projector pink hue
« on: June 19, 2020, 22:48 »
hello everyone
my projector suddenly got a pink tinge over the entire screen now
https://imgur.com/a/S88XjWi
can anyone kindly advise why this is happening?
its a sony hw50es
many thanks
Offline econav
Projector pink hue
« Reply #1 on: June 19, 2020, 23:14 »
You can chk and try .
1) unplug the HDMI cable to the projector and see what is the back ground colour .
2) press the menu key to bring up the setting menu , if also loss the green colour then good luck to you .
3) if the display menu look normal , then plug back the HDMI and chk the colour setting ( YCrCb ) does it change when you select a dif model , if it does means the setting was change and affected .
4) if your player hv a RCA video out can connect it to the video i/p to double chk and confirm is the pannel issue or colour setting issue on HDMI.
« Last Edit: June 19, 2020, 23:16 by econav »
All posts
Offline zac110
Re: Projector pink hue
« Reply #2 on: June 19, 2020, 23:32 »
i tried unplugging and the background colour is pinkish also
« Last Edit: June 19, 2020, 23:36 by zac110 »
Offline econav
« Reply #3 on: June 19, 2020, 23:47 »
point nos 2 as i say.
All posts
Offline zac110
« Reply #4 on: June 19, 2020, 23:52 »
is there anywhere or any way to repair it ?
Offline econav
« Reply #5 on: June 19, 2020, 23:54 »
of course Sony service center can replace the optical engine for you , but i don’t think the cost ........ anyone will pay for it.
All posts
Offline econav
« Reply #6 on: June 20, 2020, 00:06 »
This one RED pannel issue
This one Blue pannel issue
All posts
Offline tsammyc
  • I think, therefore I am
« Reply #7 on: June 20, 2020, 15:20 »
Reset to defaults. Looks like a HDMI colorspace issue
Online alf
    • www.entheos.com.sg
« Reply #8 on: June 20, 2020, 15:41 »
Try to use another cable to test on the same port and the other port .
Offline zac110
« Reply #9 on: June 21, 2020, 00:17 »
thanks for all the replies and answers!
so now that it unfortunately has been confirmed to be faulty, anyone with experience replacing the sxrd panel in one of these?
i am thinking of attempting to repair this, would it be worth the effort?
seems like can find the panel on ebay easily enough. but the thing i am uncertain about is the replacement process, will it require some sort of alignment and calibration after that?
Offline econav
Projector pink hue
« Reply #10 on: June 21, 2020, 00:24 »
You can buy the panel , but  is impossible for free hand to do the replacement for one panel and get it align , but you can buy a set of 3 panel ( pre- align production parts )do a drop in replace .
If you want to try.....
http://www.xtremeplace.com/yabbse/index.php?topic=166897.msg976003#msg976003
« Last Edit: June 21, 2020, 01:16 by econav »
All posts
« Reply #11 on: June 21, 2020, 12:48 »
My advice...just get another projector if you can. May not be worth all the hassles of ordering from eBay and then getting someone to help with the installation etc.
