Author Topic: MARANTZ SA8005 SACD PLAYER WITH DAC  (Read 582 times)
Offline pg
« on: June 01, 2020, 23:30 »
SOLD.
 MARANTZ SA8005 SACD  DAC WITH REMOTE. GOOD CONDITION.  Similar quality DAC alone sells for more than this price.  Self pick up.
Product highlights:
Stereo playback for SACDs, CDs, CD-Rs & CD-RWs, and MP3 & WMA CDs
front-panel USB input (type A) for USB flash drive, iPod, or iPhone
Rear-panel asynchronous USB input (type B) for audio playback of stored computer or streaming music files, including high-res files up to 24-bit/192 kHz PCM and 2.8 & 5.6 MHz DSD (Windows and Mac compatible)
Windows PCs require free driver download from Marantz website prior to computer audio playback
coaxial and optical digital inputs for using player in digital-to-analog conversion (DAC) mode
high-performance 192kHz/24-bit Cirrus Logic CS4398 digital-to-analog converter and low-jitter dual system clock
USB ground/signal isolator technology to virtually eliminate PC noise
exclusive Marantz disc mechanism resists vibration for improved sound quality
double-layered bottom plate for vibration resistance
high-current toroidal transformer with separate rectifier stages for the analog and digital sections to prevent mutual interference
Marantz HDAM (Hyper Dynamic Amplifier Module)-SA2 used in analog circuitry for faster signal transfer and better transient response.
remote control
optical and coaxial digital outputs for CD playback
gold-plated RCA stereo analog output with selectable fixed or variable output level
full-size headphone jack with volume control
remote control input/output (for use with Marantz receivers and amps with a compatible remote control in/out jack)
SACD specs:
frequency response: 2Hz - 60kHz
dynamic range: 106 dB
CD specs:
frequency response: 2Hz - 20kHz
dynamic range: 101 dB
17-3/8"W x 4-1/4"H x 14-7/16"D
Sent from my SM-G970F using Tapatalk
« Last Edit: June 06, 2020, 17:22 by pg »
