Author Topic: HD Fury  (Read 16352 times)
HD Fury
« on: May 13, 2020, 14:31 »
Just got a loan set from our local distributor today, the HD Fury vertex 2! 4k version. I’ll be hooking this up with the spare hdmi 2.1 cables I have in the store room, accell. Just nice can test it out on both my OLED LG tv and the BenQ for HDR. From my experience, the BenQ 5700 doesn’t do a good job at tone mapping, that’s personally verified by me. The SDR 4k, as I know, is fantastic .
The HD fury could be my answer for HDR on the BenQ, as it always using the LG EDID or Sony’s EDID. Frame adapt HDR is also available.
It also allows for scaling to a higher 12 bit colour depth and using Oppo 205 player-led feature, can allow the conversion and use of LLDV / dolby vision on the Projector and Apple TV.
Let’s see how it goes . Front and back pics of the device. Stay tuned
Quick glance
Gotta bring out my colorimeter and recalibrate for HDR again. Let’s see how it goes.
If this works, then it’s a game changer! It’s an inexpensive solution for HDR with dynamic tone mapping
Any HD Fury fans here ? Please fall in.... shoot !!
Sent from my iPhone using Tapatalk Pro
Online Doggie Howser
Re: HD Fury
« Reply #1 on: May 13, 2020, 14:35 »
I have been using it on my 760ES. Works really well. See an improvement on Mandalorian and Black Panther.
I use HDR Reference mode (1000 nits) on my projector and set the HDFury to pretend it is a 1000 nits LLDV display.
Re: HD Fury
« Reply #2 on: May 13, 2020, 15:04 »
Thanks doggie howser, are you using the same model ?
Re: HD Fury
« Reply #3 on: May 13, 2020, 15:11 »
3 Models to choose from.  I am still wondering which one to get.
Offline winwinc81
Re: HD Fury
« Reply #4 on: May 13, 2020, 15:26 »
Recommend to go with the vertex 2. Web interface. Easier to nav too.
Diva if you still have 1080p sinks and maestro if you need to run long distance.. hope this helps.
Offline chimaera1982
Re: HD Fury
« Reply #5 on: May 13, 2020, 15:31 »
Hi all I have the basic vertex1 using it with Sony VPL 260ES and an old LG OLED non 4k non HDR.
I bought it initially to solve handshake issues with the 2 sinks above with my sources (Apple TV4k, Pioneer LX500, Roku, StarHub box) through the Acurus Muse Pre Pro. Works great, I set all on auto. Although now trying the LLDV trick..
Re: HD Fury
« Reply #6 on: May 13, 2020, 15:35 »
Ha, so you guys solved the HDMI handshaking problem with the FD Fury devices.  Yes, far cost effective way of doing it instead of costly long-run silver wired or optical HDMI cables.
OK, I will buy a Vertex soon.
Offline winwinc81
Re: HD Fury
« Reply #7 on: May 13, 2020, 15:41 »
Let me wait for my distributor pricelist before quote. Hold your horses at the moment ya lol.
Offline winwinc81
Re: HD Fury
« Reply #8 on: May 13, 2020, 15:47 »
Haha. Yeah. Solving handshake is the fundamentals... Playing with the EDIDs to improve the colors in-between LLDV and HDR is the Interesting part.
Just too bad.. I have no HDR TV nor prj haha
  • Trade Count: (+17)
Re: HD Fury
« Reply #9 on: May 13, 2020, 17:53 »
nice. how much is one bro roughly?
Quick glance
Re: HD Fury
« Reply #10 on: May 13, 2020, 18:05 »
I got the Vertex 2. Seemed really easy and used by someone in AVS with the 760ES.
I used his settings.
Vertex 2 Guide
Assumes you're putting the Vertex 2 between the receiver and the projector.
Go to the web page for your Vertex 2, click on Config tab. Go down to FW Update. Upload new 0.49 firmware. Wait a minute.
Clear browser cache, then reload page.
EDID Tab
Check Automix
Video flags TX0 (main output that is primarily for 4k)
Audio flags stereo (projector doesn't do sound anyway)
HDR Flags - check HLG as the projector does support that
DV Flags - check box
Scaler Tab
Check Autoscaling radio button
Tick box to not upscale for TX0
HDR/AVI Tab
Check "Use custom HDR... input is LLDV"
EOTF, set as SMPTE ST 2084, BT2020-2, D65
Max luminate 1000
Min Luminance 0.005
Max CLL 1000 (matches HDR Ref on Sony)
MaxFALL leave at 400
Click Create IF
Click Send HDR
DV Tab
Construct Custom DV Data Block
DV Interface Low Latency 12 bit YCbCR 422 (haven't tried other options yet)
Primaries DCI P3
YUV 422 12 bit supported
Global Dimming not supported
Backlight not supported
Backlight min lum n/a
Set primaries. Unless you have your own values from calibrations, I suggest you stick to the standard RGB primaries.
Max luminance, set at 1000 nits to match the Ref HDR curve. Min luminance, set at 0.005, which seems to work well with projectors.
Click create, then send DV.
OSD Tab
Change fade time as it gets flipping annoying...
Config Tab
Check HDCP 1.4 to make it quicker syncs and slightly less bandwidth, therefore slightly better reliability on long runs
Enjoy!
If I find anything that needs tweaking, I'll update the post.
Offline winwinc81
Re: HD Fury
« Reply #11 on: May 13, 2020, 18:09 »
Vertex 2 Guide
EDID Tab
Check Automix
Scaler Tab
HDR/AVI Tab
Max luminate 1000
Min Luminance 0.005
Click Create IF
Click Send HDR
DV Tab
Primaries DCI P3
OSD Tab
Config Tab
Enjoy!
Nice nice!
Offline winwinc81
Re: HD Fury
« Reply #12 on: May 13, 2020, 18:10 »
Vertex 2 Guide
EDID Tab
Check Automix
Scaler Tab
HDR/AVI Tab
Max luminate 1000
Min Luminance 0.005
Click Create IF
Click Send HDR
DV Tab
Primaries DCI P3
OSD Tab
Config Tab
Enjoy!
Have you tried putting between the source and receiver instead, then to prj?
HD Fury
« Reply #13 on: May 13, 2020, 19:00 »
No idea man, its a loan set. Got the loan from winwin the distributor here but the feedback is positive from AVForum users. I don’t know, I haven’t tested. Cant confirm how good it is at this stage.
Gathering some information and will be testing this out personally, looks like a great device for HDR tone mapping , let’s see.
« Last Edit: May 13, 2020, 19:11 by ronildoq »
Re: HD Fury
« Reply #14 on: May 13, 2020, 19:14 »
Thanks doggie howser! I’ll try it out. I’ll be using player-led dolby vision from Oppo, vertex2 PJ. Not running it through the avr for now. Test it first see how it goes
I’m keen to check out the quality of the dynamic tone mapping for HDR on the HD fury, that’s my main focus with this toy
