Author Topic: quick question - is it easy to change wall outlet to USA outlet?  (Read 1250 times)
Offline HiFi
I would exercise caution with US type wall plate as if there is a fire and insurance will not honour. I rather use the Furutech wall 13A wall plate and their HiFi 13A fuses at the connectors, with direct wiring from the DB. The biggest improvement is the using good wiring point to point without sharing and it is very much less improvement from just the wall plate.
« Last Edit: May 06, 2020, 17:29 by HiFi »
ARC Ref6, ARC PH6, Jadis Defy 7, Nottingham Ace Space deck 294 with 12-inch space arm, Clearaudio Syncro Speed Controller, AT OC9II phono cartridges. CEC TL-2X, Audio Note DAC 4.0X, Sonus Faber Cremona M, VPI Record Cleaner, Shunyata cables, Geortz II speaker cables, Audio Note VX and Vz interconnects. Using Plixir Elite BAC 3000 with full Furutech sockets and Plixir Statement balanced power cable.
