Author Topic: Repair Acoustat electrostatic speaker  (Read 927 times)
Offline tsjcsl
« on: April 30, 2020, 13:10 »
The right panel of my Acoustat 2 electrostatic has stopped producing any sound. I have had this happened some years ago and was traced to a transformer. The repairman said that he recoiled the transformer at that time. I cannot find the contact anymore.
Does anyone know of a repairman who can help?
Life is difficult without music.
Offline jtsamarinda
Re: Repair Acoustat electrostatic speaker
« Reply #1 on: May 06, 2020, 00:31 »
Are you sure it's the transformer? Did you take it out. And made a test? If so I could do a rewind.
Offline tsjcsl
« Reply #2 on: May 07, 2020, 20:51 »
I have not done a test but the symptoms are similar the previous time. Sound for softer and softer then finally died. Transformer m rewind was done and problem solved.
Offline tsjcsl
« Reply #3 on: May 14, 2020, 14:21 »
Anyone able to help with contact of repairman?
