Author Topic: Is this normal to hv dark spots on new tv?  (Read 845 times)
Offline wen
  • Why Fi-Hi when u can Hi-Fi ??
« on: April 26, 2020, 20:19 »
Got a cheapo TCL... And when at a pure brighter screen I can see some dark spots at the 4 edges, top and bottom and 2 vertical stripe (slightly) in the centre.
Is this normal? I just don't want to claim warranty and another set also the same.
Watching movie won't really notice it untill the screen is partially brighten up, like when hv a scene with bright skyline.
Sent from my SM-N960F using Tapatalk
Re: Is this normal to hv dark spots on new tv?
« Reply #1 on: April 26, 2020, 20:36 »
I seen it on my LG TV too. This is predominant for most edge-lit LED TV.
« Last Edit: April 26, 2020, 20:39 by rayleh »
Offline wen
« Reply #2 on: April 26, 2020, 20:52 »
Thks for your info. But I saw this TCL model is spec as DLED panel. DLED also suffer such issues?
Good thing is, at black/dark scenes there is no obvious backlight bleed.
« Reply #3 on: April 26, 2020, 21:04 »
Yes. This is normal for LED.
Sent from my EVR-L29 using Tapatalk
« Reply #4 on: April 26, 2020, 21:04 »
My guess may be due to the quality of the LED that casts the unevenness (LED TV is like that). My take is you can try to claim for replacement (if your warranty claim is successful) but I reckon the replacement set will be similar. Just enjoy your new TV since it doesn't affect the watching experience much. Best DLED TV I have seen is the Sony Z95 but the price is also very many times more.
Offline wen
« Reply #5 on: April 26, 2020, 21:08 »
Alrighty, thks for the clarification gurus!
« Reply #6 on: April 26, 2020, 21:11 »
Check out "Dirty Screen Effect"
https://www.rtings.com/tv/tests/picture-quality/gray-uniformity-dirty-screen-effect-dse
FALD panels fair better, but OLEDs are the best. Cost more obviously..
Offline wen
« Reply #7 on: April 26, 2020, 21:18 »
Very interesting and Informative. After reading this link, I think all of these entry level LED panels (Maybe even the mid range ones) will hv such issue .
