Author Topic: Marantz AV amp breakdown.  (Read 672 times)
Offline tan8888
« on: March 08, 2020, 17:28 »
Hi all, any recommend service guy with reasonable service cost? Thanks in advance.
Offline justDaniel
Re: Marantz AV amp breakdown.
« Reply #1 on: March 08, 2020, 18:50 »
You can go to Trusty Team at kallang. What happen to your marantz?
Offline tan8888
« Reply #2 on: March 08, 2020, 19:09 »
It go into protection mode. I switch off and on it again. Minutes later it tripped. Unable to on again.
Offline justDaniel
« Reply #3 on: March 08, 2020, 19:27 »
Check your speaker connection and your hdmi connection. Nowadays those equipments are so easy go into protection mode.
Offline tan8888
« Reply #4 on: March 08, 2020, 19:30 »
Check already. Still same.
Offline justDaniel
« Reply #5 on: March 08, 2020, 19:54 »
Plug out all speakers cable and test. If it is the same then plug out all hdmi cables and test. If it work then hdmi got problem. My marantz is having this on off issue and trusty team manage to repair but after a few months similar symptoms appear. Now I had narrow down to the second hdmi output.
Offline tan8888
« Reply #6 on: March 08, 2020, 20:02 »
May I know how much you paid for the repair job?
Offline justDaniel
« Reply #7 on: March 08, 2020, 20:07 »
I paid total of $150. They clean and refitted some of the connections. $70 for deposit and checking fees and 80 for the servicing
Offline tan8888
« Reply #8 on: March 08, 2020, 20:10 »
Trust team near mrt? No vehicle here.
Offline justDaniel
« Reply #9 on: March 08, 2020, 20:22 »
They are at 68 kallang pudding. No mrt nearby. Got to take taxi
Offline tan8888
« Reply #10 on: March 08, 2020, 20:24 »
Thanks.
« Reply #11 on: March 08, 2020, 22:34 »
Mattar mrt stat..
It is abt 10 min walking distance.
Place your Marantz inside the luggage.. then you can pull... You can take mrt save cost  :)
« Last Edit: March 09, 2020, 08:03 by whitesox »
Offline Hero
« Reply #12 on: March 08, 2020, 23:06 »
This may help u understand a common cause for the protection mode...
https://www.devroom.io/projects/repair-denon-avr-4520/
Offline tan8888
« Reply #13 on: March 09, 2020, 07:42 »
Thanks all.
