Author Topic: what's the best approach to have a +20dB rising house curve on subs?  (Read 1153 times)
Secondly, look at the timing response, how these filter Low pass high pass are affecting the frequencies
Finally look at the channel balance, stereo bass vs LFE bass, how is the transition with mains
These measurements will reveal lotsa information, the frequency response chart is just to let u know the tonal balance.
U could be right
I suspect the hpf shifted the timing of the subs quite a bit. Cos after hpf applied, bad cancellation at the xover point with my centre.
Any recommendations how to fix bad cancellation at xover point...
Appreciated :)
« Last Edit: February 10, 2020, 14:30 by sevenz »
U could be right
Appreciated :)
Yea I thought so, too many filters messing things up. Ideally I would engage all filters first, meaning measure the raw response of each sub with the filters engaged. Once they are engaged, only then u proceed to align the impulse of the subs. After which, u align against the speakers woofer impulse, the first impulse from the speakers are the tweeters
Try this approach instead to blend in mains with subs.
No harm trying, nothing wrong. U will only gain more experience by trying. U can always revert to original settings if u don’t like it
Try and observe harmonic distortion as well, that’s the risk there of boosting too much
Nonetheless, aja aja fightin!
Dual e112 subs.
Measured the thd. Depending on method, the highest thd ranges between 3-6% (20hz @ 95db) at ard 20hz area . Boost method gave it a slightly higher thd.
3-6% ok?
Sevenz, at who’s place you feel/hear the bass that makes you want to go for this approach? It’s interesting. I can dig deeper for my dual JL Audio as well but I chose to set around +6.0db so far to avoid any rattling to certain parts of my room/fixtures. The tactile effect will be “filled in” by the bass shakers with anything below 50Hz.
You have bass shakers right?
Dual e112 subs.
3-6% ok?
3-6% is ok, as Long as below 10% good to go. But do check the playback levels. Assume it’s a +20db boost, that means when ur mains and centre measures 85db at -20 dbfs, and u play at MV-10 above reference, your subs are playing at +10db above reference . Unless u playback at -20mv, then your 12” subs are playing back at reference 115db for the LFE. Check the limits on the JL, can it handle 115db without distortion? The KK 12 I had in the past is good for 100db at 30hz, anything beyond and massive harmonic distortion kicks in. That’s why it’s only ideal for midbass. But I’m not sure on the JL. U gotta do the measurements to find out
Some movies are mastered extremely hot, u will have these peaks that surpass 125db at 20-30hz.... everytime u push the subs to its limits, that single DB rise will swing the entire harmonic distortion easily past 20-60% distortion levels
That’s why for subwoofers it’s good to have ample headroom, as it approaches demanding scenes, the LFE will be hot and will demand lotsa amplifier power
Ideally u want the subwoofers to be cruising, much more pleasant
The moment the subs are playing at its limits, the sound is very different . Just playback your mains without any XO, load in a simple 2 channel music, push your listening levels higher, observe how the speakers sound as u push the volume higher
Exact same thing for the subs
3 options.
1. As mentioned by desray, use the subs for lower midbass and above, 30-40hz and above and actuators/ shakers for Low bass
2. Add on another 2 more subs to make it to 4, co locate them or stack
3. Change to a bigger 15” or 18” subs
As u were coming from a rythmik E15, u will miss the rumbles etc, the JL can give u that, but I suspect at lower levels. The difference between a bigger sized woofer and smaller one is the excursion and power also plays a part and the bigger woofers always have an edge in that it can playback effortlessly on demanding scenes, down lower frequencies
Unless Low bass is not the priority , then it’s ok
Then u will find big difference when you watch the movie “Ford vs Ferrari “, just won the Oscar 2020 for best sound editing . The engine roar from the cars...
That movie just reminded me why Low bass is a must, never mind the midbass, Low bass if done correctly, can be very satisfying . Especially for all the Hollywood movies , mostly focused on 20-30hz for the special effects
Ha my place la. :) Trying to replicate what I saw/heard on Dirac live. ;)
Hoping to get 80-90% near it for the subs' house curve and also the subs integration vs mains.
Yes I have shakers. Trying to get the best balance because shakers tend to make the tactile unnatural if played loud.
Using the dual e112 for low end to 25hz gives a more natural feel and has that low end room pressuring feel which the shakers can't give
« Last Edit: February 11, 2020, 16:38 by sevenz »
Offline Tiktokape
Just because you are running NAD AVR with Dirac Live room correction does not necessarily means that your current subwoofers are capable to replicate your old subwoofers - specifications and sound signature still plays a part in it. On top of that, Dirac Live room correction is meant to aid one in tackling the room issues especially for an untreated room.
Sevenz,
Here is an article on harmonic distortion, Hope that helps
https://www.audioholics.com/loudspeaker-design/audibility-of-distortion-at-bass/total-harmonic-distortion-thd
Using REW, Go with CEA-2010 burst tones to verify your distortion numbers when u dial in a steep +20db rising curve
+20db boost down to 20hz post eq is massive, that’s why u can’t find any settings on REW that allows that much boost. I’m guessing that the 12” JLs will be in distortion territory...it may not bottom like the kk. But could well be in distortion territory
Even on the seatons f18, I don’t dial past +8db. There are guides that an ideal number ranges from 4-10db. Most of the bunch settle at 8, including me. Heck even mark told me to use one that’s +4-6db... but I went with +8db
http://www.brentbutterworth.com/cea-2010-measurement-manual.html
Use this manual above from Brent Butterworth to do a CEA-2010 test for distortion . Zoom in to 20, 25hz and 31.5... I think the measurements will tell u immediately if it’s worth pursuing this route...
Any other JL E112 users here ? Able to share the limits on this sub and their distortion numbers ?
Thanks Ronil. Understand on the distortion, will be careful on the very low frequencies. Trying to see if can reduce the rising by a few more dB yet not sacrificing the tactile. The natural curve of the dual E112 at my MLP has a 3-5db natural rise to 25hz.
Actually, u reminded me of 1 thing. Think i forgetful liao. I've been always using 25hz and 95hz for my E112 for the house curve. Slipped my mind. I'll stick to that instead of using 20hz-100hz.
Typically, I watch at main volume 65-74 on my marantz AVR depending on the source content. Like True Legend mid bass scene, i watch at about 74. Gravity at 65-69.
here's the data from databass.
https://data-bass.com/#/systems/5c12cb567f98c40004412ea6?_k=cfwk29
« Last Edit: February 11, 2020, 16:50 by sevenz »
See this, I have the same experience, why I moved away from 12” subs and kept the 18” seatons . The above is coming from other members in avs. I prefer to read comments from users, rather than online paid reviews
Once u have experienced / owned a rythmik 15”, going back to JL 12”, this is what u will be missing.
This is precisely why I recommended u either move to a bigger sub or add more subs, for the tactile. Boosting like the above doesn’t really work, it only makes it worse with all sorts of distortion and headache when dialing in.
When it is too steep, the other problem u have and gotta ask is,
What if that particular sound track already has a built in house curve?
Say that sound track has been mastered with a +6db curve Low frequency rising, u will now have a +26db curve!  Then u start to grab that remote, lower the levels, and the next thing u find out, the centre channel dialogue sounds too soft.
Then u grab the remote adjust the centre channel levels.
In the end, u sell the centre channel speaker, thinking it is not good enough... then the cycle continues. Actually all the issue lies in dialing in a correct house curve for a good balance
Nonetheless, no harm trying and experimenting, u will be able to personally experience and understand your subs better
