Author Topic: Audyssey House Curve Revisited...  (Read 5389 times)
« on: December 08, 2019, 19:57 »
While I have recently discussed about the benefits of enabling Dynamic EQ (DEQ) in your AVR. For those not using miniDSP or equivalent device to create that "custom" house curve, you can still do so by using the Audyssey MultEQ Editor App (both iOS and Android available). The constant gripe that many Audyssey users faced is the lack of that "gritty" bass slam which occurs in the region of 20Hz to 55Hz thereabouts. Audyssey did a fantastic job in "flattening" the frequency response from 10Hz to 22KHz...sometimes too "good" can be a bad thing as it tends to rob you of the natural "room gain" that your your speakers and subwoofer(s) needed at the modal frequency range. This creates an anaemic bass. We have also learned about the "loudness perception of bass" at the lower spectrum of the frequency range. In gist, the lower the frequency, the more gain in SPL is needed to get the same level of loudness (with 1KHz range as the common baseline).
To regain back those "room gain" that Audyssey destroys, we can "replenish" it using a DSP (e.g. miniDSP) or simply use Audyssey's very own MultEQ Editor app. The issue with the latter is the lack of online tutorial to teach us the basics of how to go about implementing a proper custom house curve and not to mention the endless frustration of using the App on a smaller screen like your smart phone or even a tablet if we are using our fingers to create that custom curve settings. I have recently came across a third party app styled, "Ratbuddyssey App" which is a Windows-based program albeit not perfect but does a few things right - e.g. setting precise Max EQ for the frequency range - e.g. from 20KHz down to say 250Hz/300Hz (Schroeder FR) as well as the ability to exact gains/cuts to the target Audyssey curve (Reference Curve).
I will be covering a short tutorial on how to use the App itself to implement a custom house curve to regain that much-needed "ommph" back in the 20Hz to 55Hz range. This method will kind of "clash" with the DEQ-RLO concept which I have touched on a while ago. As such, we will be disabling DEQ if we wish to implement a custom house curve here. I have found a way to make this work the way I intended. So if you are interested to know how to do it, do stay tuned for the upcoming tutorial in due course...
« Last Edit: December 08, 2019, 19:59 by desray »
Offline winwinc81
Re: Audyssey House Curve Revisited...
« Reply #1 on: December 08, 2019, 20:26 »
Nice, this will be interesting!
« Reply #2 on: December 09, 2019, 08:52 »
Nice sharing desray !! Good job! I’m sure this will help many people out there
One of the many reasons why I like to visit this forum, it’s AD free
Lotsa good technical knowledge too, and that kind gesture to continuously share that knowledge is what makes this place attractive
This subject definitely needs visiting .....
Offline sijusid
« Reply #3 on: December 10, 2019, 16:04 »
Looking forward to this thread.
My relationship with deq is love and hate.
 I like the way it handles bass boosts, but don't like the way, it boosts surround channels. I usually compensate by lowering the surround channel levels. Like it better that way.
Offline winwinc81
« Reply #4 on: December 12, 2019, 13:42 »
am wondering, if can enable the DEQ, but without the bass... wont it be nice :P
« Reply #5 on: December 21, 2019, 20:44 »
For those looking forward to this unofficial tutorial to create a custom house curve using just the Audyssey MultEQ Editor app, it will be out later tmr...working on it now as we speak. You will need the following:
1. Audyssey MultEQ Editor App (iOS and Android compatible - paidware)
2. Ratbuddyssey utility which can be downloaded from here: https://github.com/ratbuddy/ratbuddyssey/releases/tag/v0.2.1
3. A Google Drive account
4. A laptop or PC with Windows OS installed - this is required since we will be using Ratbuddyssey utility which will run on a Windows OS
« Last Edit: December 21, 2019, 20:50 by desray »
« Reply #6 on: December 21, 2019, 23:26 »
Can't wait for it, Desray. Thanks in advance!
« Reply #7 on: December 22, 2019, 11:44 »
Sorry for the delay in making this tutorial...I've been kinda busy for the past few days. As mentioned earlier in this thread, Audyssey did a rather good job in "flattening" the frequency response from 10Hz all the way to 20,000Hz. Many did not realize that our speakers and subwoofers "interacts with our room" in ways that we may not realize. For instance, you may come across some AV articles that mentioned "room gain" which comes about when sound waves travels and bounce around within the confines of our listening area. Sometimes this so-called "room gains" is needed to in order to "preserve" that "chest slamming" bass that we seek while other times it can also work against us if we fail to "tame" it - i.e. the undesirable effects of boomy and bloasted bass in the frequency range that we wish we can avoid. This is where most EQ in the likes of Audyssey, YPAO, Anthem ARC Genesis etc comes in to eliminate those side-effects of poor room mode. In short, room gain can be an allied to us if we perform Audyssey EQ calibration correctly.
In order for us to get a "custom house curve" that fits our "room mode", the pre-requisites are to get your speakers and subwoofer placement correct and then perform a proper Audyssey calibration. One misconception - One cannot simply raise the subwoofers by a few dBs and hope to get that "chest-slamming" bass kick. As mentioned in my earlier posts, there are 2 ways to create custom house curves - one way is to get an external DSP like miniDSP which worked in tandem with Room EQ Wizard (REW) but it involves some learning curve to know how to use it. The other way which is much easier is the use of an app called "Audyssey MultEQ Editor" which is available for both iOS and Android users. Besides allowing users to perform Audyssey calibration by syncing the results with the AVR connected via our home Wi-Fi network, it also allows the users to make finer adjustments to the frequency curve (via Curve Editor feature found within the app itself), turn on/off the Mid-Range Compensation (MRC) or even dictates the frequency range for Audyssey EQ filters to be applied. Some speakers tends to perform better with music when there is no EQ filters being applied to a certain frequency range. Some purists even believe that the max frequency range for Audyssey EQ filters to be applied should fall somewhere within the Schroeder frequency which usually falls between 100Hz and 300Hz. In my opinion, a good starting point will be somewhere between 500Hz and 5,000Hz (ARC recommendation).
Of late, I discovered a nifty utility (not perfect though as the creator has no time to iron out some of the kinks but for the most part, the “key” features work so let’s cut him some slack :P ) called Ratbuddyssey which can be downloaded from here: https://github.com/ratbuddy/ratbuddyssey/releases/tag/v0.2.1. This little utility albeit "buggy" is a god-send imo. It allows us to make finer changes and adjustments on the original Audyssey calibration file (.ady) and then import back to the Audyssey MultEQ Editor App to be uploaded to our AVR. If you ask anyone what is the biggest gripe using the Audyssey MultEQ Editor App; most will say the App itself requires a larger screen estate like on a tablet to allow them to “see” and make changes to the frequency curve and even then, it is STILL hard to make some changes with precision using just our fingers or even a stylus. This is a real PITA if you ask me!
The Ratbuddyssey utility paired with Audyssey MultEQ Editor App certainly makes life a little easier for me these days since I can implement and test drive all variations of house curves within matters of minutes and that’s what makes it such a joy to use.
Enough said, let’s dive into the tutorial on how to setup a custom house curve using just the Audyssey MultEQ Editor App without the need for miniDSP (assumption made that you have already achieved a somewhat reasonably good frequency curve for your subwoofers AFTER Audyssey calibration and for that I meant you are able to get a reasonably “flat” response curve from 10Hz to 120Hz thereabouts.
« Reply #8 on: December 22, 2019, 12:03 »
Let’s say that we want to boost the modal frequency range (say 20Hz – 50Hz) by +3db for our 2 subwoofer(s). The first thing you need to do is export the Audyssey calibration file (.ady) over to our laptop so that we can use the Ratbuddyssey utility to make finer adjustments to the curve. This is the preferred method over the use of the Curve Editor feature found in the Audyssey MultEQ Editor App. Although you can still use the Curve Editor feature found within the Audyssey MultEQ Editor App to create your custom house curve and it will still work...but you will probably get a headache trying to get the “boost” at the desired frequency center. So do yourself a favor by downloading the Ratduddyssey utility to your laptop/desktop PC before you read on...
How to export the (.ady) file? Simple, use the “Move to” function on the Audyssey MultEQ Editor App and then select the desired (.ady) file and then hit “Send a Copy”. You will see the option that says, “Copy to Drive” as in Google Drive. The (.ady) will now be exported from the App and into your Google Drive folder.
Next, go to your laptop/desktop PC and open up a new session on the Ratbuddyssey. Select “File” then “Open” to select the (.ady) file in your Google Drive folder.
Once opened, you will see the interface will be populated with all your associated speakers and subwoofers which resides at the left pane of the utility.
Next, uncheck the DynamicEQ (DEQ) checkbox. Ensure that the Audyssey Curve Type is set to “Flat” (default) instead of “Reference”. An optional setting like MRC (Mid-Range Compensation) can be turned off easily just by unchecking the check box and it will apply to all speakers. Make sure the Custom Speaker Type is set to “Small” for all the speakers (FL,C,FR, SLA,SRA,SBL,SBR etc) and the subwoofer(s) set to “Subwoofer”.
Next, set your Frequency Cut-off range for speakers (Only) to anything between 500Hz and 5,000Hz. I will advise the user to set it at 500Hz as a good starting point and slowly work your way up until you find a good “blend” where your Mains and the subwoofer(s) complements each other in a constructive manner. This is where the crossover points come in. To optimize your Mains crossover to the Subwoofer(s), you can use REW and Umik 1 to help you find the best crossover points (I will not be touching on this in details but I will share what I meant if there is enough interest being generated). Let’s just say that you decide to crossover your Mains at 80Hz (THX Fixed) so anything below 80Hz will go to the subwoofer(s) while anything above 80Hz will go to the Mains. As for subwoofer(s), make sure you restrict the Frequency Cut-off to either 200/250Hz.
The rest of the options remain intact...any changes like increasing the crossover and trim levels can be performed at the App level since it is much easier and intuitive. We mainly used Ratbuddyssey to allow us to make finer adjustments to our curve setting.
Now comes the important bit – i.e. boosting the level (SPL) by +3db (as an example). More often than not, the so-called “mid-bass punch” or “chest-slamusually falls anywhere between 20Hz and 70Hz. Depending on your crossovers between the Mains and the subwoofer(s) which is usually 80Hz for most bookshelf/tower speakers as well as its corresponding SPL levels, somewhere between 65Hz to 70Hz, we will start to see some roll-off if we set our crossovers to the ubiquitous 80Hz. Hence the safest region to implement a boost IMO will be somewhere between 20Hz and 60Hz. There is no right or wrong answer here, simply experiment it to hear for yourself which suits you better in your listening area. The keyword here is “your listening area”, not mine due to the difference in “room gain”.
In my room, I find 20Hz – 50Hz at a 3-4db boost to suit me the best in my listening environment (a typical 4 x 4 room layout). I can increase up to +6db if I truly want to feel more punch with a higher level (SPL). Sometimes, there is no need for you to go all the way to +6db boost if your subwoofer(s) is capable of outputting high levels (SPL) at a low-frequency range. So know your subwoofer’s capability and experiment it for yourself.
How to add the boost to the various frequency range for the subwoofer(s)? For this, you will go to the Target Curve Points panel located just below the Channels panel. Type in the following:
Frequency Center/Boost:
20Hz at +3db
50Hz at +3db
170Hz at 0db
What this does to your target curve can only be viewed after you have exported the modified (.ady) with the custom "house curve" back to the Audyssey MultEQ Editor App. Before we do that, we still need to apply the same amount of boost to the same set of frequency centers (20Hz, 50Hz, 170Hz & 400Hz) for the Mains like so:
20Hz at +3db
50Hz at +3db
170Hz at 0db
400Hz at 0db (assuming we set our Frequency Cut-off range at 500Hz)
Hold on, we are not done yet! Often overlooked by many users is to apply the same amount of boost to the subwoofer trim levels. The reason for that is because of the way the Audyssey MultEQ Editor App works. Let me explain as best as I could here...
When we boost the subwoofer(s) by +3db for frequency range from 20Hz and 50Hz, the Audyssey target curve will do a "self-course correction" by lowering the entire curve by the same amount of boost you applied. Why is this so? The reason behind this is simple. Audyssey is trying to ensure that the overall SPL level for the subwoofer(s) and the rest of the speaker arrays will “sound” the same at a given volume level. In so doing, whatever boost we have applied to the subwoofer(s) will not be translated to the “actual” results since there the boost to the target curve has been “pushed down” (becomes a cut)  by Audyssey. In order to overcome this, we have to apply the same amount of boost (in the is case +3db) to the trim levels of our subwoofer(s). So how do we do it? You can either do it at the App level or within the Ratbuddyssey itself. For the latter route, add +3db under the “Custom Level” text field. DO NOT simply at +3db and call it a day. Instead, you will need to add +3db to the original SW level.
For instance, if the initial trim level for your 2 subwoofers as follows:
Subwoofer 1 (SWMIX): -1.0
Subwoofer 2 (SWMIX): -2.0
You will need to add “+3db” to the original trim value which will give you:
Subwoofer 1 (SWMIX): +2.0
Subwoofer 2 (SWMIX): +1.0
That’s it! You are done! Click on “File” and “Save As” and give it a meaningful filename like Audy_DDMMYY_boost3db_DEQ_off.ady (as an example).
Next, export the modified (.ady) file – i.e. Audy_DDMMYY_boost3db_DEQ_off.ady to the same Google Drive folder.
Once the export is completed. Do the following:
    - Select the “” icon to the right of the file
- Select the “open in” option; it will prepare to export the file
- Swipe to the right and Select “More
- Select the “Copy to MultEQ” option
- The Audyssey MultEQ Editor App will automatically be launched and append the new (.ady) calibration file – i.e. Audy_DDMMYY_boost3db_DEQ_off.ady into the main screen
[Skip this step] if you have already add the boost amount on Ratbuddyssey...
If you have not yet added the boost of +3.0db to the trim levels for your subwoofer(s), now is the time to do so by going over to “Speaker Detection Results” option and go to the second tab that allows you to change the Levels (SPL) settings to reflect the same:
Once that is done, import the new modified (.ady) calibration file over to the AVR. You are done!
What’s next?
Play some familiar 2 channel music...set the Sound Mode to “Stereo” or “Direct” and then “Pure Direct” (cut off subwoofers and set the Mains to LARGE), feel and hear the difference that your Mains (after adding a +3db boost to the modal frequency range – i.e. 20Hz and 50Hz), you should “feel” and hear a much more impactful low extension coming from your Mains (especially for those who have a pair of tower-sized speakers or bookshelf speakers that can go down to 40Hz and below).
After the 2 channel test, you can put in a movie like the Opening scene of Edge of Tomorrow or the famous True Legend fight scene that I know many XP members adore...Hear the difference and I can almost guarantee you that you will hear a significant difference in the low-frequency extension that DEQ cannot provide.
Take your time to slowly digest it...Post any questions if you have any.
« Last Edit: January 25, 2020, 08:33 by desray »
« Reply #9 on: December 22, 2019, 12:54 »
Additional Tips:
1. Try as many variations in boost as possible using one session and then export the modified (.ady) calibration files to the Google Drive folder to be imported into the Audyssey MultEQ Editor App for A/B comparison.
2.DO NOT remove the original Audyssey calibration file...
3.Do A/B comparison between "flat" Audyssey Reference Target Curve and the new custom "Reference Target House Curve". This will allow for a more objective assessment.
« Last Edit: December 22, 2019, 12:57 by desray »
Offline sijusid
« Reply #10 on: December 22, 2019, 16:37 »
@desray
Thanks for the guide and tips.
Appreciate your efforts.
One question, the boost for the mains, shouldn't this be proportional to the rated FR of the speaker. I mean, if the fronts are rated up to 40hz or 30hz, shouldn't we start the boost from there, or it dosent really matter?
« Reply #11 on: December 22, 2019, 19:34 »
One question, the boost for the mains, shouldn't this be proportional to the rated FR of the speaker. I mean, if the fronts are rated up to 40hz or 30hz, shouldn't we start the boost from there, or it doesn't really matter?
It really depends on what crossover you have set for your Mains to crossover. What is your Mains crossover? If you truly want to know what is the best level (SPL) and at what frequency to introduce the boost...you need to utilize REW with a calibrated mic like Umik 1. Take note, you don't really need to increase by the "same amount" of boost (SPL level) for your Mains...the key here is to try and get the level (SPL) for the Mains to be more or less within the same level as the Subwoofer(s) output level (after boosting it by 3db in this case).
« Reply #12 on: December 22, 2019, 19:40 »
I may consider to open up a demo session next Sat (28 Dec 19) to showcase the difference between Audyssey with DEQ set to 'On' but no house curve (since DEQ is in itself a house curve) versus Audyssey with DEQ turned 'off' but utilize a custom house curve. Of course, for those who want to learn to add a custom house curve but don't know what the heck am I talking about in those steps, I will run through a hands on session with you as well.
See if there is any interest here...
« Reply #13 on: December 22, 2019, 22:07 »
wow nice. thanks for documenting & creating this for the benefit for all in XP bro.
Super useful esp for those who wants to deploy house curve in an easy way
Offline sijusid
« Reply #14 on: December 23, 2019, 10:01 »
Thanks once again for your write-up.
The windows program is quite good and easy for tweaking, but unfortunately, it didn't worked for me. After uploading the tweaked file to my avr through app, there was no sound coming through any of the speaker. Couldn't figure out the reason.
So i had to do it the difficult way of tweaking it in app itself. I have extensively used the app before and so i am quite used to editing the curve on my mobile (however i do agree that windows program is much easier).
Before your write up, i too used to give a similar boost on my mains. Subwoofer also, i had tried earlier, but could never hear any difference, the reason i now know why, thanks to you.
For my case, i had to give 5db boost across the mains and subwoofer, to get it sound the way i like. I boosted from 20 to 70 hz on subs and 35 to 70hz on my mains.
Personally, i always used deq before, but only like it for bass but didn't liked it the way it  boosts high frequencies (more shrill sound). Also the boost in surround channel was a bit annoying for me.
But now, without deq and curve tweaks, bass is more tight and highs are controlled.
Thanks once again. Couldn't have asked for better holiday gift. It worked for me and i am sure, it will work for others too.
