Author Topic: No sound from rear surround speakers while playing dolby atmos disc  (Read 2315 times)
Offline justDaniel
I am having 7.1 channel bi-amp setup. Two front speakers, one center, two front height, two side surround and two back surround.
While playing UHD disc(Endgame) from Sony X800, I press the info shows all active speakers except two rear speakers.
Successfully did an Audyssey calibration and tested the tone from all speakers are working properly. I tried all settings but still the same - no sound from rear speakers.
Am I doing something wrong?
Online chaozhoi
Were there any sound coming from ur rear speakers? Press info from ur avr do u see ur rear speakers active?
Sent from my Mi A1 using Tapatalk
Offline pcking
Which AVR are you using ?
Based on your description you have a total of
Front Bi-amp = 4 channels
Front height = 2 channels
Side surround = 2 channels
Back surround = 2 channels
Center = 1 channel
11 channels.
If you are not using any external power amps, your AVR needs to have 11 active powered channels.
Offline justDaniel
I am using Marantz SR 7011.
I setup according to the manual.
When I press info. in the remote control, the input shows only Dolby Atmos.
No diagram to show how many channel of input.
Offline justDaniel
When I press info. only rear surround speakers are not active.
The rest are actives
Offline pcking
Try to execute the test tones to check if the connections are correct.
+1
When you do a test tone, you should know if there is any sound.. you can download this..
Offline pcking
Not necessary to download test tones.
Can execute manually inside the AVR menu - Manual setup - levels.
There should be test tones playback for you to adjust the levels.
Offline justDaniel
I did the test tone and every speakers tested have sound.
Even while playing the disc, I did the test tone all speakers tested with sound.
But when switch back to movie the info shows rear speakers not active
Offline pcking
Try switching to other Movie Sound modes to hear if the rear surrounds come on.
Offline justDaniel
I tried that still the same.
I did not purchase the Auro 3D so can't test.
Offline pcking
Does it only happen when the source is D Atmos?
What about when source is DD or DTS ?
Offline justDaniel
Tested DTS and the same result.
Online chaozhoi
Any menu from ur avr that looks like that? It shows in and out. Ur Blu-ray info might only be showing what it is outputting
Offline justDaniel
Yes the menu look like this except that the "Input Signal" does not show diagram but the word "Dolby Atmos"
The output active speakers shows all but not the rear surround speakers
