Author Topic: Bass on a budget  (Read 1359 times)
Offline LWCM
Bass on a budget
« on: November 14, 2019, 10:14 »
Hi can I ask which would be a better choice for about the same budget?
Brand new Wharfedale sub below $300 OR 10 years old velodyne slightly above $300?
Re: Bass on a budget
« Reply #1 on: November 14, 2019, 12:55 »
Ive seen too many Velodynes that have destroyed themselves (amps blown and takes out the driver often too) so IMHO I would go with something newer and with Warranty.
« Reply #2 on: November 14, 2019, 13:02 »
+1...go for something else other than Velodynes.
Online rayleh
« Reply #3 on: November 14, 2019, 13:30 »
If you can stretch your budget, there is a used Rythmik LVX12 for sales. This should be better than the subs you have mentioned.
Offline LWCM
« Reply #4 on: November 15, 2019, 18:23 »
Wharfedale is very cheap. Anyone has it and what’s your feedback?
« Reply #5 on: November 15, 2019, 21:44 »
@ $300 new anything is cheap (MIC)...get what you pay for usually in this budget / bracket. As the old saying goes "pay peanuts get monkeys". YMMV
maybe see if EarthSound have any good subs traded in.
Online rayleh
« Reply #6 on: November 15, 2019, 22:24 »
You won’t get much from a $300 sub. Suggest the pre-owned Rythmik if you can up your budget.
Offline spencert
« Reply #7 on: November 16, 2019, 22:44 »
Sorry... I kop the Rythmik LVX12 already.  ;D
 Just connected it to my iMac, AudioEngine A5+ and AudioEngine D1 DAC. Totally satisfied... for now.   ::)
« Reply #8 on: November 17, 2019, 23:34 »
If u are open to used gear, just get a used sub of a renowned brand/model. But do some research so that u won't go wrong.
By getting used subs, with the same amt of spending, u usually can get a sub of much higher quality vs a new sub.
Plus, when u decide to sell it away next time, u probably can get back most of your cost. In a way, it's minimum/no cost to you. Just holding power.
So far, most of the subs I bought b4 are mostly used subs and 95% of the purchases have been ok. But do have ways to test them properly and I would avoid subs that are too old.
« Last Edit: November 18, 2019, 14:16 by sevenz »
« Reply #9 on: November 18, 2019, 10:32 »
I would caution against the old sub.
The plate amps are usually the first to go.
And they would be expensive to replace.
I’d rather just save up and get a good sub.
Offline LWCM
« Reply #10 on: January 09, 2020, 11:40 »
As an update I got an old Velodyne CHT-10R. Very happy with it. Punchy and tight.
