Author Topic: Aurender latest W20SE music server @ X Audio  (Read 148 times)
Offline Xaudio
« on: October 10, 2019, 15:04 »
Aurender Flagship W20SE music server is now available @ X Audio
Since its launch in 2013, the Aurender W20SE has occupied the enviable position of “the music server others are judged against”. Revised and refined in 2019, the new W20SE (Special Edition) raises the bar again in both user experience and absolute audio performance.
W20SE is the music server of choice for the finest audio systems in the world. Designed to be used with high-performance digital-to-analog converters, the Aurender W20SE is one of the few music servers to provide support for external word clocks used in professional audio and recording studios. Additionally, a dual-wire mode AES/EBU used by some reference grade digital-to-analog converters to allow separate transmission of left and right channels for better fidelity. However, even without using an external word clock input or dual AES/EBU outputs, W20SE’s battery power supply provides a dramatically lower noise floor for a totally silent background. With a 4TB internal SSD and a 1TB SSD caching drive for playback, the W20SE is the ideal solution for even the most extensive high-resolution music collections.
Key Features:
.Innovative Technology with Battery Power, Dual-Wire AES/EBU, Master Clock Input
.Full Range of Digital Audio Outputs and Ports for Network Connectivity
.Aurender Conductor App Packed with Convenient Features for Full-Function Control
.MQA Core Decoder Installed
.External Word Clock Support
.Dual-Wire Mode AES/EBU
.Separate LiFePO4 (LFP) Battery Power Supply for the Audio Circuitry
.Internal UPS Protects W20SE Under an Abrupt Power Outage Condition
.Oven-Controlled Crystal Oscillator (OCXO) for Long-Term Jitter Reduction
.Precision DSD-to-PCM Conversion by FPGA
.FPGA-Based All Digital Phase-Locked Loop System
.4TB Solid-State Drive Storage with 1TB Solid-State Cache Drive for Playback
.Dedicated USB Audio Class 2.0 Output with Ultra Low-Noise Power Circuitry
.Linear Power Supply
.2X Isolated LAN Port
.USB HDD and NAS (Network-Attached Storage) Support
.Remote Internet Technical Support
For more information, kindly refers to the following link:
https://aurender.com/w20se/
Price: $30K
1 Jalan Anak Bukit, #01-01S
Bukit Timah Plaza
Singapore 588996
Tel : 64662642
Our Facebook Page:
https://www.facebook.com/Xaudio.sg/
Address:  1 Jalan Anak Bukit, #01-01S
                Bukit Timah Plaza
Operating hours - Mon-Fri 1230-2000
                            Sat - 1100-1900
