Author Topic: MO , Acoustic Artwork panel ( Cancel)  (Read 7162 times)
Online Earth Sound
  • ... by sound enthusiast
    • www.earthsound.com.sg
« on: October 06, 2019, 20:47 »
Hi,
In order for the order to take place we  would require a minimum order of 12 pcs . Some have ask for 1 to 3 pcs , so we based on this MO and consolidate the orders , cut off date 20th Oct 2019 , 2300hrs . Interested party pls input your nick and type of artworks require , 50% payment  is require for this .
1.
Pricing as follows if use existing artwork options:
600 x 600 mm @ $150 ea
1200 x 600 mm @ $200 ea
1200 x 800 mm @ $250 ea
MOQ of 12 panels to go.
For customise artwork, additional $25 per image. All we need is a high resolution picture of your choice … family portrait , favourite photo, movie poster etc.
Existing artwork options. More available for selection soon.
Samples available @ Earth Sound
Satisfied customer
« Last Edit: November 14, 2019, 07:52 by Earth Sound »
| www.earthsound.com.sg | Facebook @ EarthSoundSG | Authorised dealer for StarkeSound, JVC, Ken Kreisel, Gallo Acoustic, Rythmik, Frank Acoustics ,Plixir.
Contact us @ 9092 1582
Lazada store @ https://www.lazada.sg/shop/earth-sound/
Offline yuriais
Re: MO , Acoustic Artwork panel
« Reply #1 on: October 06, 2019, 21:15 »
Hi Scott, can I check what is the thickness of the panel? Also is the price inclusive of delivery and installation?
Sent from my VOG-L29 using Tapatalk
« Last Edit: October 06, 2019, 21:38 by yuriais »
« Reply #2 on: October 06, 2019, 21:30 »
Hi Scott,
I am keen to get 3 panels 1200x600. Will send you artwork shortly. If not, will use existing artwork.
Online Earth Sound
« Reply #3 on: October 06, 2019, 21:35 »
Hi Rayleh,
Noted on the request , u can whatapps me @ 97894630 .Thanks
Online Earth Sound
« Reply #4 on: October 06, 2019, 21:36 »
Orders :
1. Rayleh ( 1200 x 600 mm ) Qty : 03 custom artwork .
Online Earth Sound
« Reply #5 on: October 06, 2019, 21:57 »
Hi Yuriais,
Thickness at 2 inch , but can be customised according to your requirement and lastly doesn’t include delivery and installation which of course can be arrange on a separate cost .Thank you
Offline andylovesaudio
« Reply #6 on: October 06, 2019, 22:25 »
Hi,
Don’t see it mentioned anywhere. May I know type of absorbent material used ... foam or rock wool? Grade/density?
« Last Edit: October 06, 2019, 22:29 by andylovesaudio »
Online Earth Sound
« Reply #7 on: October 06, 2019, 22:46 »
Hi Andy ,
Is back by of 40 kg/m3 rockwool . Thanks
« Reply #8 on: October 06, 2019, 23:13 »
Many thanks for the info.
Online Earth Sound
« Reply #9 on: October 07, 2019, 07:30 »
You are most welcome .
Offline yuriais
« Reply #10 on: October 07, 2019, 08:46 »
Hi Yuriais,
Noted with thanks.
Online Earth Sound
« Reply #11 on: October 07, 2019, 08:49 »
Any other enquires , can whatapps me @ 97894630 thanks a lot
  • Trade Count: (+17)
« Reply #12 on: November 02, 2019, 22:55 »
Keeping the ball rolling. Very good price! Hope this MO goes thru!
2. sevenz (1200 x 800mm or slightly bigger) | Qty: 1 | Custom artwork
3.
Offline Ccyao
« Reply #13 on: November 03, 2019, 08:15 »
I’m actually very keen in getting 3 panels of 1200 x 600 or 1200 x 800 for my wall. The challenge that I have is to get the high resolution pictures that I want.
Where / how do you guys get your pictures?
Online Tiktokape
« Reply #14 on: November 03, 2019, 08:50 »
Can buy from shutterstock...
