Author Topic: What DVD Len's Cleaner You Use?  (Read 4140 times)
Offline sonic
  • Yes Yes!!
« on: May 12, 2002, 03:49 »
DId you use any DVD len's cleaner & what brand?
Is there a need to?
Thanks.
Offline limos
  • INFECTIOUS SUBSTANCE
Re:What DVD Len's Cleaner You Use?
« Reply #1 on: May 12, 2002, 11:03 »
IMO, there is no need to clean the lens for home cd or dvd players unless your listening room is dusty. Anyway, you might like to try Auric Illuminator to clean your discs instead.
In Case of Damage or Leakage Immediately Notify Public Health Authority
Offline variablefeedback
  • Boom! Boom! Boom! Boom! Boom! Boom! (THX)
« Reply #2 on: May 12, 2002, 11:31 »
Richard,
I agreed with SHi Fu Richard.
BTW, your dog, DAMN CUTE!!!!!
My Seller's Pledge:
1) I do not entertain buyer's remorse.
2) I will never sell any known faulty items on the internet without informing in the advert.
If buyer is uneasy about buying used items from the net, then buy a used one with some warranty life left or new one from the store.
I believe that it is unethical to sell something that is faulty (but seller do have their limitations) in any forum and claim that it is 100% OK because I am a buyer myself.
Offline queks
  • XtremePlace.Com Forever!
    • XtremePlace
« Reply #3 on: May 12, 2002, 12:09 »
Yo, variablefeedback. drop the word shi fu. There's no shi fu here. All friends and brothers here only.
*** XtremePlace ! Don't leave home without it ! ***
Offline Phil
  • HT addict
« Reply #4 on: May 13, 2002, 00:48 »
Avoid e brush type since it will most likely stratch ya len... best if u can leave it alone.... use preventive measures like cleaning ya dusty CD b4 popping into ya players.
I normally open up e player 2 clean it using e normal floppy solution & cotton bud when e len get dirty...
Phil
Offline forests_gump
« Reply #5 on: May 13, 2002, 23:22 »
Is there a need to?
Thanks.
If you die-die must do something to the DVD lens, then maybe:
Open up your player, and use camera lens blower on it.
Offline sonic
  • Yes Yes!!
« Reply #6 on: May 13, 2002, 23:35 »
Is there a need to?
Thanks.
Jus asking only if there a need to or not.
Offline davidLKH
Instead of blowing, how about sucking!
« Reply #7 on: May 17, 2002, 17:20 »
What are you guys thinking?
Anyway, how about a small vacuum cleaner that sucks off the dust.
Either way, there will be no direct contact with the pick-up lens.
Offline luff
Re:Instead of blowing, how about sucking!
« Reply #8 on: May 23, 2002, 00:00 »
Ahhh! STATIC  ;D
Offline davidLKH
Static will be there either way
« Reply #9 on: May 23, 2002, 17:07 »
If you blow off the dust, or vacuum off the dust, air will still pass over the lens.  Hence creating static.
In the case of vacuum, at least you are removing the dust into a tiny bag.
In the case of blowing the dust, you are moving the dust from one place to the another.
