Author Topic: How can I get woody?  (Read 1661 times)
Offline jerome_the_lang
« on: October 05, 2019, 09:34 »
I need to cut 4pcs of wood platform for use with equipment.
(CD transport, DAC, Turntable, Pre-amp)
Size: 527 x 398mm
Preferably 2" thick.
Question:
Solid wood or plywood better for sound?
What material you recommend?
Go where to cut?
Will they polish for extra fees?
Sat/Sun are they opened?
Many thanks in advance
 ;D
« Last Edit: October 06, 2019, 16:56 by jerome_the_lang »
Re: How can I get woody?
« Reply #1 on: October 06, 2019, 14:02 »
https://www.facebook.com/pages/Ban-Heng-Long-Trading/170490773024304
look for marine ply if they have it...most dense and solid, but you will have to layer it and glue and clamp or use weights to bond it down
« Last Edit: October 22, 2019, 11:40 by wizardofoz »
« Reply #2 on: October 21, 2019, 15:13 »
Managed to go to Ban Heng Long on Sat, and cut 4 pieces of marine plywood.
Total cost: $88
« Reply #3 on: October 21, 2019, 19:20 »
Individually they sound "resonant" when I tap on their surfaces.
Should I be concerned?
Should I try to dampen the resonance?
What's the best way?
Offline jaffrie
« Reply #4 on: October 23, 2019, 15:29 »
If your concern with resonance, the best way is to cut alum sheets of 2 mm thick to the size of your boards & stick them together using contact adhesive. This will damped it out.
« Reply #5 on: October 26, 2019, 12:37 »
Got me some 50mm thick acrylic
 ;D
Hurry to bring them home, so no polish for now
