Author Topic: ARC HDMI cable  (Read 414 times)
Offline jerome_the_lang
ARC HDMI cable
« on: September 27, 2019, 14:25 »
Do you take into consideration about signal flow directionality of HDMI cable?
Specifically, what is your signal flow directionality preference the HDMI cable being used from Amp to TV with auto return channel (ARC) duo purpose?
Do you connect so that signal directionality is correct based on: from AVR to TV to ensure the best picture quality but then the audio returning from the TV is not optimal
Or
Do you connect so that signal directionality is correct based on: from TV to AVR to ensure best sound from using the TV as a source, but picture quality playback from blu-ray player not so good?
