Author Topic: Restoring Bass in movies using Bass EQ’ed  (Read 10799 times)
Offline Djblackfm
Re: Restoring Bass in movies using Bass EQ’ed
« Reply #15 on: July 20, 2019, 00:28 »
Bro u can also use your lyngdorf, mobile to load in the filters, that will be fast
Hello Bro,
Yes. Lyngdorf is currently a one stop solution to all this. I'm still glad I went to this. Thank you for your guidance
Offline winwinc81
« Reply #16 on: July 20, 2019, 00:47 »
Noob question here.
Using behringer DSP...So if I already calibrated in such a way that I have the curve already with all those peq settings in behringer filters band, does it mean that I have to add or minis using that corner recommended chart to achieve better experience?
What I'm trying to express my thoughts is, example I need to +2db at freq 50hz so that I have flat house curve for bass due to room modes.. then, the chart says example...need to -3db at 50hz to have better experience, so I have to adjust my house curve to -1db at 50hz? Not sure if you guys get what I'm trying to say
Offline Djblackfm
« Reply #17 on: July 20, 2019, 01:07 »
Hello Jag,
I have some queries hope you can help me.
Do we need to know/understand our subwoofer limitations first? Because if we keep adding alot of filters(PEQ/LS) we would bottleneck our subs? Probably an example some subs unable to go as low as 15hz-20hz.
Apart from MiniDSP, I believe Behringer amp (DIY sub) their software (but limitations on it   is their filters only able to go 20hz if we use peq) I believe lowshelf could help & able to do lower than 20hz
(I'm still out at the moment but rest assured I will post pictures of MiniDSP plugins software, Behringer plugins software & dual core antimode) sorry for the delay guys.
Pictures I got it from the internet.
Behringer Amp(nx3000d), I'm using it on Ultimax 18"
« Reply #18 on: July 20, 2019, 01:25 »
My understanding is if your sub is not able to go low then BEQ will not be beneficial. Example: I have dual SW12 and they don't dig low below 20hz so no point for me to apply BEQ to my miniDSP.
Offline winwinc81
« Reply #19 on: July 20, 2019, 02:02 »
Yup, have to see how low it was tuned and if there is any hardware limitations... But there are "hacks" which can trick the hardware to go lower one way or another that I saw before (should be AVS I think)
Offline ngsk
« Reply #20 on: July 20, 2019, 09:38 »
Atomic Blonde BassEQ Demo Scene (UHD, PCM 7.1)
https://mega.nz/#!9EcnmSzI!HKi40Y0TiPGkyh4dNOmiV4DqT9v7ltzvPzvC6xg_yfg
Ready Player One BassEQ Demo Clip (UHD, PCM 7.1)
https://mega.nz/#!hcMBGSDS!F66toa6Ub_sM-RIRW9S71E7U_k99ySphwCVSZSgo7A4
The Meg BassEQ Demo Clip (UHD, PCM 7.1)
https://mega.nz/#!pQtGjaaA!84cbEecRXPf8bo_6B23-KEITGTWi0A-QI7HT33fOxOc
Olympus Has Fallen BassEQ Demo Scene (PCM 5.1)
https://mega.nz/#!RJU12IqK!YgcbVVie4YxgziG1HdssqV2MuKYB8LLtGPtCoQFvxQ4
Flight of the Phoenix BassEQ Demo Scene (PCM 5.1)
https://mega.nz/#!pNN1SS7K!n7LOgZh6rfpLiFxZlHaq9tqWyTD7lChwqHiZC1ebkG4
Finding Nemo BassEQ Demo Scene (PCM 7.1)
https://mega.nz/#!8AUVnCbD!fCrCZsmT5w7LViCDz3_X_eZexOPIwajRdcbaEB01vmI
Some demo clips with BEQ done by 'aron7awol' the guy that did most of the BEQ filter on the BEQ thread on avsforum. Play those clips with caution,can't believe they BEQed Olympus Has Fallen Washington Monument collapsed scene,there's 20+ seconds pure 20hz content @high spl within this scene,1 of the most demanding 20hz scene ever mixed even without BEQ.
'These are reduced in level to prevent clipping. The filenames will tell you by how much. You should increase your MV by that amount if you want it to play at a normal level.
They each contain two tracks, with and without BassEQ, so that you can switch back and forth while playing to compare.'
This is how he make those clips & what MV to playback.
« Last Edit: July 20, 2019, 09:53 by ngsk »
Online rock123
  • Enjoy HT Fully! :)
« Reply #21 on: July 20, 2019, 12:15 »
Slam Wow Solid stuff NGSK many thanks.
100% HT Lover 6.2.4  2.35:1 150' CYRUS Phantom Grey MK II 4k/UHD
BenQ W2700 4K HDR   Source: Oppo 203 & Egreat A5
1996 Sunfire Cinema Grand l Flagship Onkyo RZ-3100 11.2 THX® Select2™
M&K Sound LCR950 THX Select2 Series
Sub 1: Rythmik FV18 @900WRMS
Sub 2: SVS PB12-Plus/2 @900WRMS down-firing dual 12.3" three 4" Ports
Offline Djblackfm
« Reply #22 on: July 20, 2019, 13:43 »
If I'm not wrong, I think we only can add in PEQ for antimode. For the lift & tilt is like a fix placement.  Let me head home later snap some shots on the dual core(before I offload it) & MiniDSP 2x4(non-hd) for anyone reference if needed.
Minidsp 2x4 Non HD version. 2 way plugins
« Reply #23 on: July 20, 2019, 14:11 »
Thanks for sharing. Appreciated. Personally I felt those titles are already very good with normal listening. The ones that truly can benefit are those Disney Marvel titles imo...are there any of those with BEQ optimised?
« Last Edit: July 20, 2019, 14:14 by desray »
Offline Djblackfm
« Reply #24 on: July 20, 2019, 14:12 »
Thank you bro! Shall test it out later
« Reply #25 on: July 20, 2019, 14:14 »
I'm kinda late to this post, but here's my take on BEQ.
BEQ restores deep bass that many studios intentionally remove.... Many studios are now apply heavy filtering to bass <25hz so heavily that it will make high end subs sound like HTiB sub.
How it works is:
1) There are a group of passionate HT enthusiasts that use software to analyse the type of ULF filtering the studios use and reverses that filter.
2) That filter is then loaded into a MiniDSP as a BEQ curve.
3) This BEQ curve works along simultaneously with your room correction EQ and house curve EQ.
4) RCEQ + HCEQ + BEQ...... all 3 EQs work together to :
      a)Room Correction EQ (Dirac Live) will correct for peaks and dips and produce a smooth frequency response. Room acoustic imperfections is responsible in uneven frequency response peaks and dips.
      b) House Curve EQ is that bass boost (mid bass thump or ultra low frequency vibrations) that some like.
      c) BEQ will restore and bring out the lowest ULF and correct for filters that the studios impose on their titles.
5) Once you have applied BEQ, together with capable subwoofers, you will want to watch your movies all over again.
BEQ settings can be automatically uploaded to your minidsp via a HTPC, or you can do it manually based on the settings usually given in the top right corner of the FR charts associated with each movie.
BEQ only works with Minidsp at the moment. Other EQ platforms are not compatible, unless you know what you are doing.
I have been using BEQs for about a year now and I must say that BEQ is a must if you truly want to enjoy your movies and the subwoofer you truly deserve. No more mickey mouse bass just because the studio decides you to have anemic bass.
Better late than never. Always appreciate your inputs and insights.
« Reply #26 on: July 20, 2019, 15:41 »
For those interested on how to do a remux...here's a detailed step-by-step guide.
Reading material - Primer (Impt!): https://www.avsforum.com/forum/113-subwoofers-bass-transducers/2995212-bass-eq-filtered-movies.html#post56610164
Download the BEQDesigner app here: https://beqdesigner.readthedocs.io/en/latest/ to create and upload the BEQ filters
For those who have the MiniDSP, follow these steps to upload the BEQ filters for the selected movies: https://github.com/bmiller/miniDSPBEQ
Save or bookmarked this Github for the latest updates on the list of updated BEQ'ed movies from the creator: https://github.com/bmiller/miniDSPBEQ/tree/master/Movie%20BEQs
Enjoy!
WARNING!
Remember these are content independent. This is NOT a set-once-and-forget-it. So do be careful when playback as you never know how your subwoofer(s) can handle the increased ULF. So try it out at a safe MV (Master Volume).
« Last Edit: July 20, 2019, 15:51 by desray »
« Reply #27 on: July 21, 2019, 10:40 »
How it works is:
Thanks Jag for sharing! All nicely summarised
Lol Mickey Mouse bass indeed from all the Disney movies 🤣
« Reply #28 on: July 21, 2019, 18:06 »
super good topic & discussion. love it  :)
Offline winwinc81
« Reply #29 on: July 21, 2019, 21:53 »
Yup agree. Call "atmouse" effect.
