Author Topic: BenQ W2700 DLP Projector Thread  (Read 8307 times)
Re: BenQ W2700 DLP Projector Thread
« Reply #30 on: January 06, 2020, 13:41 »
Oh it’s yours !! Fantastic, very nice bro, congrats! Good job
They look very nice and beautiful
Online rock123
    • Bass EQ for Filtered Movies
« Reply #31 on: January 08, 2020, 23:36 »
New firmware V1.0.5
https://www.benq.com/en-ap/support/downloads-faq/products/projector/w2700/software-driver.html
Bro Many thanks for the heads up.
Yesterday downloaded firmware unzip few times copied files seem not working.
Today, finally the file is good! Upgraded to 1.05 with success :)
Played a HDR 10 movie,
tested preferred settings at the moment as below.
         Dynamic Iris  : High
        Brillant Colour : ON
Wide Colour Gamut : OFF ( Colours look wierd and subtitle look blueish if ON)
Cheers.
BenQ W2700 4K HDR   Source: Oppo UDP-203 & Zidoo Z9S
Sunfire Cinema Grand 5 Channel l Denon AVR-X4400H Pre-out @7.4.4
M&K Sound LCR950 THX Select2 Series  miniDSP 2x4 HD\WI-DG *BEQ*
SYS 1: Dual Rythmik FV18s  Dual Hsu Research MBM-12 MK2 (nearfield)
SYS 2: Dual Sunfire True Sub EQ , SVS PB12-Plus/2
Online rock123
« Reply #32 on: January 08, 2020, 23:39 »
ETC : The firmware upgrade took estimated 15 mins from current fresh 1.0.0 to Latest version 1.0.5
Offline tsammyc
  • I think, therefore I am
« Reply #33 on: January 09, 2020, 15:14 »
         Dynamic Iris  : High
Cheers.
Bro, if you have good light control or if you are watching at night, the most number of colors are Brilliant Color off, Wide Color Gamut On. However, that is the dimmest setting and no good if you don't have very good light control.
If its slightly bright, say, a little bit of stray light coming in at night, I have Brilliant Color Off, Wide Color Gamut Off
If I watch during the day with the blackout curtains down, but letting in some light through the sides, I have Brilliant Color On, Wide Color Gamut Off, which is the brightest picture, but the lowest number of colors
If you have Brilliant Color On and Wide Color Gamut On, you will have a bluish tint
Online rock123
« Reply #34 on: January 09, 2020, 18:31 »
Fantastic bro great sharing experience really appreciate them for lightning control and night scene.
The WCG mode really interesting.
Will test it too cheers thanks so much.
Offline alf
    • www.entheos.com.sg
« Reply #35 on: January 12, 2020, 19:23 »
This is another way of mounting which allows you to have more head room in smaller room .
The screen also have to be raised up a bit more just to be able to slide back wards for better viewing distance .
This is a 92" 16:9 Phanthom Grey MK II , it was recommended because it gives a better blacks base on the light colour wall in the room .
There is newer material which are able to make the image even blacker and have more contrast that also can be use . It depends on the personal views and upgrade bugs are with them .
« Last Edit: January 12, 2020, 21:14 by alf »
Offline nur_hsc
« Reply #36 on: April 07, 2020, 10:26 »
Hello, i just joined w2700 community yest. Picture splendid previously fm w2000.
But it us normal after off, its still make noise a few min.?
Online rock123
« Reply #37 on: May 05, 2020, 16:32 »
A good review out there for the BenQ models.
https://www.projectorcentral.com/BenQ-HT3550-v-BenQ-HT5550.htm
Offline tsammyc
« Reply #38 on: June 16, 2020, 20:58 »
A bit late to Gemini Man as I just got the Blu Ray. Posting the same picture from the W2700 in some of the other projector threads
Click here to zoom
Shot on iPhone X
« Last Edit: June 16, 2020, 21:18 by tsammyc »
« Reply #39 on: June 16, 2020, 21:08 »
Shot on iPhone X
Nice one! It seems like "this scene" in Gemini Man has become the de facto screenshot for XP to showcase projector PQ :P
