Author Topic: My HT Journey resumes. Setting up NEW BenQ 5700 PJ from Scratch N Considerations  (Read 19790 times)
Alright, just got news that pick up for screen will be today by UPS, standard cheapest shipping option, usd600 for the 135” screen.... faint... shipping is much higher as the size is bigger , screen cost $925, total usd $1525 before GST, arrival early June
Just finished meeting my previous contractor for grid system, he can do it to my specifications, nice, all in, one stop solution... screen I’ll have to assemble myself however... will get some help... here is another video of the assembly, it comes with a thin black bezel, really sleek looking, elite AT screen
<a href="http://www.youtube.com/v/VMmlrUSYoI4&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/VMmlrUSYoI4&fs=1</a>
I would love to have the flip up screen type, like this video, done by youthman, quite carefully thought out and planned... see how convenient he hides the cables, using a wheel for the console, so he can have easy access to cables and speakers, and how the flip up screen works, using hydraulic hinges
<a href="http://www.youtube.com/v/9rQxNd1Lf38&fs=1" target="_blank" class="new_win">http://www.youtube.com/v/9rQxNd1Lf38&fs=1</a>
Nice ! Too bad I can’t do flip up, ran out of height space with grid system eating 20cm into heights, and console 55cm heights, so no choice, just go with hook it up fixed screen
Next, I ordered some 15m uGreen CAT 7 ethernet cables, a pair of 15m Fiber HDMI 2.1 cables Moshou Brand , and a 15m trigger cable, all from aliexpress, these will go through the grid system and right back behind MLP
The Moshou HDMI cables are good, can do 12k material without stuttering, vs my 4K certified HDMI cable... so yea, good stuff, able to carry the bandwidth ... just not sure how good is the chip for this fibre version, but the trust is there after using the non fiber chip version..
These will be connected onto a custom made board like this, where the BenQ 5700 sits
Right at the back centre of MLP , above the seatons stacked, below the air conditioner
With a pipe like stuff so we can align the PJ if needed as recommended by bro ccyao, thanks bro !
Now that I’ve gotten the basic and easier things out of the way, it’s time for the most difficult part, the THX baffle wall itself!
So many options and considerations, but I decided to go with this ...
First things firsts, why all the hassle ? Cos I can tell you it’s totally worth it ! Being a HT enthusiasts, this is almost a must. Why?
1. When the speakers are placed vertically behind the AT screen, the dialogue and vocals and sound image will track the onscreen actions, vocals will emanate from where it’s supposed to, it creates a type of realism where the sound is anchored on the screen, very immersive
Why vertical placement ??
See this simple diagram above, horizontally placed speakers will have lobing issues
So the recommendation would be
Simple pics and easy to understand .
However, I can’t go with this, as I would have to get another floor stander to sit inside behind the AT screen. At the same time, if changing just the centre speaker out for an in wall type speaker, I’d have to change all front 3, otherwise I will have timbre matching and coherence issues... so how?
MAKE DO! Adjust , I’ll share again the plan
2. Apart from superior tracking of onscreen dialogue and action, the next benefit is speaker boundary interference, eliminated, as the speaker is flushed onto surface of the wall. There is now no more boundary interference issues that introduces massive peaks and null down lower frequencies
3. Visual and aesthetics. As can be seen, it’s beautiful, here are samples of neatly done designs, taken from web and friends feeding me all sorts of info & ideas
See how nicely it can be done... just need the $$$.... but boy, they have very good acoustical benefits
4. Better Low frequency output. With the option of having subs built into the wall, this translates to a better headroom, approx 6db down Low.
5. Better transient response, if the wall is solid enough, then the subs will benefit
However, I’m not going to put the seatons in, but cater for future upgrades, two slots available
6. Less diffraction on sound for the speaker flushed into the wall
7. Front wall acting as a massive bass trap.
What I’ll do now is to use this wall as a bass trap, meaning I’ll have the centre speakers sit on he middle of the screen, where tweeters are aligned with the left right floor standers. And then on all 4 corners of the centre speakers, flanked with SMT wings , like this. The centre will sit right on the 60x60 smt, horizontally...
The two front height speakers will sit in the baffle wall as well
On the remaining empty wall, it will have 60kg density rockwool , 100mm size. Sandwiched Behind an mdf & a gypsum board, with 20cm air GAP .... this entire front wall will now act as a bass trap, with good air flow resistivity , they will all be absorb bass. black fabric wrapped to absorb light and have less sound attenuation , the purpose of the mdf wood is to provide varying density....
It’s important to note that filling up the entire front wall with rockwool will not help as the Atmos/ front height speakers and surrounds actually deflect off front wall to provide that diffused soundfield . So I want to retain the liveliness, hence going with 60kg density rockwool
Finally will have another layer of velvet material covering light reflections off ceiling....
I’ll try and draw out the diagram on excel ... to be continued ...
Offline Wilber
  • Trade Count: (+7)
good pick for the fibre hdmi cable, I'm using it as well, looking forward to visit.
HT Setup
Marantz AV8802A, JBL Professional Speakers Powered by Harman Crown DCI amps. Zidoo X9S. Clef Cleansource Power Regenerators, Optoma UHD65, Panamorph Lens With Powered Sled, Prismasonic Curve Frame with UF Fabric, Fibaro Home Automation.
Computer Setup
KEF Reference 1 Powered by Harman Crown DCI amp, Topping D90 (AK4499)
Offline synthesis
Another option. Interested in custom speakers? Size can be adjusted based on space constraint.
Sure Wilber, soon, hopefully should complete by End June19, contractors in on 3rd week of June to fix it all up.
Ill PM you when all ready, most likely will be one of the sundays 2.30pm in July19
Good to know u r using the same fiber cable with no issues, happy to note that !
Hi Synthesis, will get in touch with you, if i decide to go DIY midbass modules to sit in line behind into the baffle wall, thats one of the future upgrade plans, there will be two slots for subwoofers behind mains, keeping that option open
Offline Ccyao
Don't mention Bro!
Never have the knowledge to share the technical stuff. Happy that I'm able to contribute. Haha
Really amazed with and admire your passion and the hard work that you have put into your HT journey. A joy for me to read!
Offline Ccyao
Bro, may I join in, if you don't mind?
Sure will reserve for u both when ready, will PM u ... thanks again for the tip
Offline Ccyao
Finally arrived from USA !
135” AT screen from elite, total damage $2.3k to door step inc GST
Next up, awaiting materials to arrive, 3rd week of June building the baffle wall, still some work to do...
Already gotten myself a copy of the new HDR10+ using Dynamic Metadata , all ready , can’t wait to check out the BenQ in HDR10
Those who have witnessed first hand the Tekno3d files on the OLED will understand what I mean...  this version is the TOP version compared to the previous one
  • Trade Count: (+17)
Whoa... arrived!
Exciting!
Yea man! Journey resumes very busy past few days
Layout ready , this Monday contractor  start work, weekend will be projector screen assembly, fingers crossed not much of a headache, will try our best !
Boundary woofers checked, Intended XO 500hz !
4x. F18 Seatons will move to handle Just LFE up to 90hz
Centre behind AT screen flanked by all 4 world class SMT wings ! Centre channel is the key , apart from the subs
Front heights left right behind 135” AT screen !
60kg density rockwool 100mm to work as bass trap
Screen will be flushed into the baffle wall , covered with black fabric
Here we go again...
« Last Edit: June 04, 2019, 22:50 by ronildoq »
Ok journey resumed again, before that, big THANK YOU to bro Wizardofoz who popped by all the way today to help me with the screen assembly
sharing here some of the pics taken
First we hooked up the corners of the frames
Then the edges L shaped
Then the screen and the  followed by the support bar
Looks from the front, huge 135” ! Not used to it
Close up look at the material , acoustic transparent
Wrapping it up, standby for Monday contractor to do up the baffle wall
Corner thin black bezels will be optional
Elite forgot to include the hooks, so couldn’t install the black cloth onto the back of the screen, so will have to wait for the hooks to come in... here is how it looks
nonetheless, installation will have to proceed, may not be too bad as the wall will be made of gypsum board with black fabric wrapped rockwool
Back Edges will be fitted with a remote control 10m bias lights , with dimming options
Long week ahead !
