Author Topic: Recommend upgrade for surround speaker for Marantz SR5013 Amp  (Read 189 times)
Offline cochran
Hi
As before. Was looking to get the Denon X2500 amp. But at the end gotten the Marantz SR5013 as it have better spec and cheaper than the Denon.
Ok. Current my speaker setup is
2 x front Pioneer S-HF10 speaker. Its a 200w 6ohm speaker.
centre and 2 rear surround is an old Infinity minuette sat speaker. spec as:
SPECIFICATION S SATELLITE S
Frequency Response 200Hz- 20kHz
Crossover Frequency 5kHz
Sensitivity 87dB @ 1 watt, 1 meter
Nominal Impedance compatible with 8 ohms
Power Rating Use with amplifiers rated between 15 and 80 watts RMS
Drivers 3 Vz" shilded woofer and W polycarbonate tweeter with acoustic lens
SPECIFICATION S CENTER
Frequency Response 150Hz-20kHz
1 meter
Drivers 3V2"shilded woofer (2 pes) and W polycarbonate tweeter with acoustic lens in D'Appolito configuration
Looking to check the rear surround and centre speaker. Any intro?
Was thinking to get the cheap Onkyo SKH-410 Dolby atmos enable speaker to place on top on my old Pioneer S-HF10 for Dolby atmos effect as have the extra 2 speaker channel to use.
Any expert?
Thank you.
